12F629 Won't SLEEP
Results 1 to 8 of 8
Threaded View
  1. #5
    Put a space between @ and SLEEP.
    Edit: I guess this bears a little more detail. What happens is by placing @SLEEP in
    there it doesn't generate code for SLEEP, so you land on the next valid instruction
    which would be your GPIO.1 = 0.
    You don't have the @ symbol before your NOP either, so PBP creates a lable instead
    of code for the NOP. @ NOP would be the correct way to insert an assembly NOP
    instruction.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. sleep on 12f629
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 8th February 2007, 15:08
  3. 16F628A current high during sleep
    Last Post: - 9th October 2006, 11:21
  4. Wierd sleep issue
    By orca in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 23:06
  5. Programming 12F629 low power (Sleep)
    By Warrier in forum mel PIC BASIC Pro
    Last Post: - 29th November 2004, 15:45
