12F629 Won't SLEEP
Results 1 to 8 of 8
    Is my problem so stupid that no one will give me suggestions? I believe I have read everything, and tried many things. Please help. Thank you.
    Put a space between @ and SLEEP.
    Edit: I guess this bears a little more detail. What happens is by placing @SLEEP in
    there it doesn't generate code for SLEEP, so you land on the next valid instruction
    which would be your GPIO.1 = 0.
    You don't have the @ symbol before your NOP either, so PBP creates a lable instead
    of code for the NOP. @ NOP would be the correct way to insert an assembly NOP
    instruction.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Quote Originally Posted by jderson View Post
    Might just be only BRUCE saw the problem.
    Thank you Bruce and Joe! The space solved the problem. Staring me in the face all along!
    well, that explains why i couldn't get a pic to sleep either. lol
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. sleep on 12f629
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 8th February 2007, 15:08
  3. 16F628A current high during sleep
    Last Post: - 9th October 2006, 11:21
  4. Wierd sleep issue
    By orca in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 23:06
  5. Programming 12F629 low power (Sleep)
    By Warrier in forum mel PIC BASIC Pro
    Last Post: - 29th November 2004, 15:45
