Accelerometer Sensor
Results 1 to 19 of 19
    That is what I meant. Every movement will have to have an opposite in order to zero it out. The problem I see would be making sure that always happens in the math. Making that many readings and trying to get them to zero out in such a short period of time I would imagine would be very difficult.
    Jun 2006
    Default Freescale MMA7455L
    Hi, I'm developing a localizator with the accelerometer MMA7455L, but it don't works.
    Someone used this sensor?
    I'm using a PIC16F88.
    I'm connected the pin 1,6,7 to 3,6 VDC; the pin 2,5 to GND, the pin 14 to micro's SCL and the pin 13 to micro's SDA. SDA and SCL have two 4,7K pull up resistors. I try to read some register without answer. I try to connect pin 4 to GND, but without effect. Is the device address $1D?
    Have you some software example for read and write the registers with I2C Bus? Can you help me?
    This is a piece of code:
    IND1 CON $1D '%00011101
    PAUSE 2000
    MAIN:
    ADDRESS=$1A
    I2CREAD SDA,SCL,IND1,ADDRESS,[TMP]
    DEBUG "MODE1 ",BIN8 TMP,13,10
    PAUSE 1000
    thank you
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 22:42
  2. Is this a K Type sensor?
    Last Post: - 21st November 2009, 13:55
  3. PICBASIC PRO-coding for wireless sensor node
    By syazila in forum mel PIC BASIC Pro
    Last Post: - 10th February 2009, 00:05
  4. Replies: 6
    Last Post: - 18th January 2008, 08:17
  5. RH/Temp Sensor Example Code
    Last Post: - 15th June 2006, 15:55
