18F2550 timing
Results 1 to 21 of 21
Thread: 18F2550 timing
    So what did you have the CPU divisor set to when it worked with HSPLL set on the MAC?
    I know zero about the MAC, but it could be that your main-line program code is too slow
    to meet the MAC USB tming. I.E. it could be that a USB device needs to check in more
    often than on a PC platform to maintain the connection.
    More details would really help.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Aug 2008
    Here's a simplified question about something I just noticed:
    on an 18F2550 with a 20MHz xtal programmed HS with no postscaler and a DEFINE OSC 20...
    Pause 2000 pauses for exactly 2 seconds
    but with the same setup...
    For cnt=1 to 2000
    Usbservice
    Pause 1
    Next cnt
    pauses just for 258ms
    Why? First off, I thought I wasn't supposed to be able to Pause 2000 and maintain my USB connection but I am. Secondly, what's with the timing discrepancy?
    How do you know it pauses just for 258ms?
    If you are not sure PAUSE 1 works, then setup a simple loop to toggle a pin, and watch
    it with a scope.
    -Bruce
    tech at rentron.com
    Aug 2008
    I know those pauses are what they are because the circuit outputs a MIDI note across USB to a host computer and an app on that host measures the time between events. Both examples should theoretically pause 2000ms between each MIDI note indicator .
    I'll try the pin toggle to the scope idea. Seems like Pause 1 will take just .129ms because 2000 times through the loop is taking only 258ms for some reason.
    I think you may be forgetting to add the time it takes for certain functions to execute.
    PAUSE 2000 pauses for 2000 * 1mS.
    For cnt=1 to 2000 ' this takes time
    Usbservice ' this takes time
    Pause 1 ' this should take about 1mS
    Next cnt ' this takes time
    Obviously, the 2nd version is NOT the same. You have to account for the time Usbservice
    takes + the time to execute the for next loop.
    -Bruce
    tech at rentron.com
    Aug 2008
    What you said could make sense if the 2nd version actually was taking longer, but it's running 8 times faster.
    remember, pause 2000 is measuring out as 2000ms but the loop example is completing in 258ms!
    I'm totally guessing here, but it sounds like you might have declared your cnt variable as
    a byte VS a word.
    -Bruce
    tech at rentron.com
  1. 12F683 serout timing
    By Hobie Cat in forum mel PIC BASIC Pro
    Last Post: - 21st December 2009, 16:57
  2. 18f2550 + 24lc512
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 20th December 2007, 22:02
  3. 18f2550 oscillator problems
    By rjones2102 in forum mel PIC BASIC Pro
    Last Post: - 28th September 2007, 03:57
  4. 18f2550 'access is denied' USB error?
    By Giulio in forum mel PIC BASIC Pro
    Last Post: - 30th December 2006, 14:29
  5. HSEROUT buffering and timing - 16F88
    By picster in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 17:52
