The PAUSE was just an example. I need every instruction and every aspect of the program to run 4 times slower than normal.
I already was using HS as you suggested and everything was fine, except enumeration would not carry out through a USB hub into a Mac. It worked in every other condition, PC and Mac. When I use HSPLL it enumerates every time in any situation. Unfortunately, my program works best 4 times slower than it does at normal speed, which was very possible using HS in the scenario I outlined above, but not possible so far using HSPLL.
