How far off is it?
If you did this...
What do you end up with as far as timing goes? Should be a 1 second pulse, 1/2 on, 1/2 off, obviously...Code:main: high LED pause 500 low LED pause 500 goto main
How far off is it?
If you did this...
I ran the test you suggested and here's what I found out:
18F2550 with a 20MHz xtal, HS, postscaler (/2), DEFINE OSC 20
makes 1ms into 4ms, which is what works perfectly for my situation.
18F2550 with 20MHz xtal, HSPLL, any possible postscaler, any possible DEFINE OSC
can't make 1ms into 4ms.
I would need to use either a higher than possible DEFINE OSC statement or a larger postscaler option. For example, DEFINE OSC 64 with postscaler (/6) would work but 64 isn't compiling.
A postscaler which is (/8) could help too but it's not an option.
Seems I should just use a different xtal. I could get that same 1ms becomes 4ms situation if I use a 12MHz or 24Mhz xtal for this circuit. Are 12 and 24 equally usable? Maybe 12 would be better because less noise?
The datasheet says 20MHz is okay to go into HSPLL. You just use a /5 prescaler and the resulting 4MHz is then used to produce a fixed 96MHz PLL reference clock.
What I can't configure however is the 4x slower operation (I want 'pause 1' to actually pause for 4ms!).
I just wanted to see if i could pull this timing thing off without having to use a different xtal. I started everything with 20MHz HS but now that I'm forced to use HSPLL, which is new to me, I know 20 won't work so I'm done with it. The reason I'm moving to HSPLL is because my circuit only enumerates consistently on PC's but not Mac's, unless I use HSPLL instead of HS.
I'm sure both 12 and 24 will work but is there any preference?...unless there is some other way to get the timing I want and still use the 20MHz xtal!
Actually, it doesn't seem possible no matter what value I choose. Using HSPLL and also somehow getting the program to run 4 times slower is tougher than I thought. Now I will probably start experimenting with changing my ADC_SAMPLEUS value as well as all my PAUSE and PAUSEUS statements...
Why do you want PAUSE 1 to pause for 4mS? Can't you just use PAUSE 4?
Note you do not have to use HSPLL. With a 20MHz osc you can set the PLL divisor to
/5, USBDIV /2, and the USB core will run at 48MHz. You can set FOSC = HS and set the
CPU divisor to CPUDIV = OSC1_PLL2 and use DEFINE OSC 20.
The PAUSE was just an example. I need every instruction and every aspect of the program to run 4 times slower than normal.
I already was using HS as you suggested and everything was fine, except enumeration would not carry out through a USB hub into a Mac. It worked in every other condition, PC and Mac. When I use HSPLL it enumerates every time in any situation. Unfortunately, my program works best 4 times slower than it does at normal speed, which was very possible using HS in the scenario I outlined above, but not possible so far using HSPLL.
