Interrupt questions
Results 1 to 6 of 6
    Default Interrupt questions
    Hi all,
    I'm working on a module to receive data from a logger and display the data on a LCD.
    From my previous post i came up with a solution to receive the data from the logger into an eeprom. I'm using the code:
    DEBUGIN [DEC VALUE]
    All works fine except when the logger stops sending data and i have to go back to the main menu to display the received data.
    I thought of using interrupts but came across some issues:
    First let me show you the test code:
    'PIC 16F88 - module for logger
    CMCON=7      'comparators off
    CVRCON=0     'Vref Off
    CCP1CON=0
    T1CON=0
    TRISA=%00101010
    TRISB=%00000011
    INTCON.1 = 0 'Clear RB0/INT External Interrupt Flag bit & re-enable interrupts
    'DEFINEs
    @ DEVICE INTRC_OSC
    @ DEVICE MCLR_OFF
    @ DEVICE PROTECT_OFF
    DEFINE OSC 8
    @ DEVICE CPD_OFF
    @ DEVICE LVP_OFF
    @ DEVICE BOD_OFF
    @ DEVICE PWRT_OFF
    @ DEVICE WDT_OFF
    ADCON1=%00000000
    ADCON0=%00000000
    ANSEL=%00000000
    ' DEFINE LCD pins
    DEFINE  LCD_DREG        PORTB
    DEFINE  LCD_DBIT            4
    DEFINE  LCD_RSREG       PORTA
    DEFINE  LCD_RSBIT           6
    DEFINE  LCD_EREG        PORTA
    DEFINE  LCD_EBIT            7
    DEFINE  LCD_BITS            4
    DEFINE LCD_COMMANDUS 2000
    Include "modedefs.bas"                 'Include serial modes
    DEFINE DEBUG_REG PORTA
    DEFINE DEBUG_BIT 0
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 1
    DEFINE DEBUGIN_REG PORTA
    DEFINE DEBUGIN_BIT 1
    DEFINE DEBUGIN_BAUD 9600
    DEFINE DEBUGIN_MODE 1
    'PINS
    out     var          PORTA.0  'also used for ICSP
    in      var          PORTA.1  'also used for ICSP
    LED     var          porta.2  'change led for a button
    A3      var          porta.3  'NC
    a4      var          porta.4  'check PCB
    pgm     var          porta.5  'reserved for ICSP
    RsBit   var          porta.6  'RS-Bit for LCD
    EBit    var          porta.7  'E-Bit for LCD
    BUT1    var          portb.0  'interrupt button
    BUT2    var          portb.1  'button2
    SCL     var             PORTB.2  ' eeprom SCL pin
    SDA     var             PORTB.3  ' eeprom SDA pin
    lcd4    var          portb.4  'Data pin for LCD
    lcd5    var          portb.5  'Data pin for LCD
    lcd6    var          portb.6  'Data pin for LCD
    lcd7    var          portb.7  'Data pin for LCD
    'variables
    value    var        WORD  'value received
    INIT:
    high out
    debug $0D, $0A,13,10
    PAUSE 50
    debug "Module initialization...",13,10
    lcdout $fe,1,"initialization"
    STP:
    lcdout $fe,1,"1-READ - 2-WRITE"
    debug "1-READ - 2-WRITE",13,10
    IF BUT1=1 then
    WHILE BUT1=1
    WEND
    INTCON=$90
    On Interrupt Goto stall
    GOTO rd
    IF BUT2=1 then
    WHILE BUT2=1
    WEND
    GOTO wt
    GOTO STP
    rd:
    lcdout $fe,1,"choosen 1-READ"
    DEBUGIN [DEC VALUE]
    lcdout $fe,1,"1-READ...cont"
    pause 1500
    INTCON=$80
    goto stp
    wt:
    lcdout $fe,1,"choosen 2-WRITE"
    pause 1500
    goto stp
    disable
    stall:
    lcdout $fe,1,"pressed interupt"
    INTCON.1 = 0
    pause 1500
    resume
    After checking the manual, it states that it should have the RESUME line. So far so good, but i dont what it to resume but instead go to one label and then go where ever i want. So i did this:
    stall:
    INTCON.1 = 0
    pause 1500
    'resume
    goto stp
    The result was that the program after the interrupt just stayed looped inside the labeled stall.Is it a must to resume ???
    One other thing is that following the manual's example of placing
    INTCON=$90 'start interrupts
    Does not work because pressing the button it goes directly to the labeled stall ( not passing through the labeled rd ).
    I changed it with
    And this way works as expected. Is the manual wrong ?
    One last thing i noticed is that when a PAUSE command is being executed the interrupt needs to wait until it jumps to it's label.
    This is also true with the DEBUGIN [DEC VALUE] command. Meaning that not receiving any data it will hang here. The interrupt will not cancel this line.
    Being true how can I cancel the input of data when it's finish ??
    Sorry for the long post
    You are right that the interrupt routine won't execute untill the current PBP statement is finished so it WILL hang on the DEBUGIN statement. This is clearly stated in the manual and the biggest drawback of PBP's way of handling interrupts in Basic. Regarding RESUME....You could say RESUME Label and the execution will continue at Label instead of where it was interrupted.
    However, it seems to me that a simple timeout may be enough and DebugIn HAS an optional timeout function that you can use to jump back to your main routine if no data is received within the specified time - that is, as soon as the dataline has been "silent" for the specified time it jumps to the routine of your choise.
    If you need to use interrupts in more advanced way than than PBP offers natively then look no further than to Darrel's Instant Interrupt routines, it lets you write your interrupt code in Basic without the drawback of PBP way of handling it.
    ...that is, as soon as the dataline has been "silent" for the specified time it jumps to the routine of your choise.
    Only if is silent (ie no noise) AND it idles in the correct state.
    Greetings HenrikOlsson ,
    thanks for the tip about the timeout, i didnt noticed it.
    I will try it, but i think it's the most logical way to do this.
    I've noticed that the timeout is used in milliseconds, but it doesnt say what is the max value it can accept?
    I will need maybe 30sec at least.
    Melanie,
    thank you also for reminding that. Makes perfect sense
    I'm not sure what the maximum timeout value is but I'd guess it's 65535. If you find the limit to be lower than what you need you could stack multiple DEBUGIN statements so when the first one times out it jumps to the second etc.
    Works as expected
    thanks
    @ Melanie
    I used a 33pF cap between signal and gnd to reduce noise.
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Can't ID interrupt source with this IntHandler??
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. ON INTERRUPT questions
    Last Post: - 19th December 2005, 20:47
