Ok good point, the first one i looked at had internal thermal cutout on it so this one probably does too. Ill make sure to get heatsinks just incase though.
Volume control isnt really a problem. I want the amp to be turned up as high as possible (without causing distortion) then turn the volume up and down on the PC that controls everything.
Are these chips safe to run directly from a PC? The diagrams for the LM386 show a variable resistor between the input and the chip. Since i dont want volume control can i just remove that completely or does there need to be some kind of resistor or protection device in place?
