Interrupt portb
Results 1 to 9 of 9
Thread: Interrupt portb
    Use a stack of 10F200's, GP1/GP2/GP3 interrupt inputs, GP0 is a serial interrupt output, simulated 'open-drain' setup, feeding a master PIC on RxD. A bit like the stacked interrupt chain (8259? 8279? INT2?) on the old PC's...
    10F200's don't have interrupts.
    Thanks everyone, I am using the 16F628A. I will go back to the datasheet and see if I can make out what it is talking about.
    I know...used the term interrupt in the wrong context...
    What I meant to get across was 'a very tight loop, polling the pins, waiting for an event on any of the input pins, and reacting to that input event with an output event on another pin.'
    The 10F2xx may not have interrupts, but they do have Wake-From-Sleep, which might be just as good. (just noticed, the 10F doesn't have a RETFIE instruction either!)
  1. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 20:52
  2. shifting problem
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 07:11
  3. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
  4. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
