DT interrupt/pulse generator
Results 1 to 15 of 15
    Quote Originally Posted by Adrian View Post
    I imagined that the programme overhead would mop up 'some' 'ticks' but I was surprised when it ended up at 107 adrift.
    You can count that out yourself. Just look at the .lst file, run thru the instructions manually and count them (branches, goto's, returns, retfie, all take 2 cycles, check the datasheet).
    If you know that number down to the exact cycle, you should be able to program in a specific frequency and check your oscillator frequency against that with a reasonable amount of accuracy.
    Adrian,
    All latencies can be easily compensated for, by ADDING the reload value to the timer instead of just copying the value to the time.
    At the time the interrupt occurs, the value of the timer is 0, and it continues counting while the chip is doing what ever it has to do to get to the Handler.
    When it gets to the handler, and is ready to reload the timer, the timer already has an EXACT count of how long it took to get there. So when you ADD the const to the timer, it actually subtracts the time it took from the const and EVERYTHING is accounted for.
    Take a look at this page ...
    http://www.darreltaylor.com/DT_INTS-...rTemplate.html
    That program has everything you need, but at a minimum, check out the ReloadTMR1 routine which shows an easy 8 instruction cycle adding reload.
    hth,
    May 2007
    Suffolk, UK
    Darrel
    Thank you very much. I have taken a look and 'instantly' it doesn't look so easy to understand, however it also appears to be very crafty and very useful. I am going to plug away at your code until it IS understood and then add this new-found knowledge to the ever increasing store of accumulated wisdom from all of you experts.
    Many thanks again to you for enlightening me and of course to Skimask for his valuable input
    Adrian
    I have taken a look and 'instantly' it doesn't look so easy to understand, ...
    It does look a bit confusing at first, but it couldn't be easier.
    A complete understanding of how it works will come later after getting it to work.
    This is really the only section you need to digest.
    Set Freq to 2000, Prescaler to 1, and T1CON to 0. Fill in the Main program and T1handler that gets called on each interrupt.
    Done deal.
    ;--- Change these to match the desired interrupt frequency -------------------
    ;--- See http://DarrelTaylor.com/DT_INTS-14/TimerTemplate.html for more Info.
    @Freq       = 2000                ; Frequency of Interrupts in Hz
    @Prescaler  = 1                   ; Timers Prescaler setting
    T1CON = $00                       ; $00 = Prescaler 1:1, TMR1 OFF
    ; $00=1:1, $10=1:2, $20=1:4, $30=1:8 --  Must match @Prescaler value
    @ INT_ENABLE  TMR1_INT            ; enable Timer 1 interrupts
    GOSUB StartTimer                  ; Start the Timer
    ;____Your Main Program goes here______________________________________________
      ;   ---- Your Main Program goes here ----
    GOTO Main
    ;____This routine is Called on each TMR1 Interrupt____________________________
    T1handler:
      ;   ---- Your interrupt routine goes here ----
    @ INT_RETURN
    May 2007
    Suffolk, UK
    Default DT Interrupt - saga continues!
    Darrel
    Many thanks - the programme worked spotlessly up to 1KHz. I put Freq as 1000, T1CON as 0 and Prescaler as 1 plus I just added TOGGLE PORTB.0 in the T1Handler section. With any frequency up to 1000Hz the output on PORTB.0 is (as would be expected) exactly half the frequency value. At any frequency above 1000Hz, which appears to be a magical threshold, the output is not half. e.g. at 2000 it is 1042; at 1500 it is 781; at 1200 it is 625 and even at a small increase over 1000 Hz it is still wrong ie at 1020 it is 521. What is the logical explanation for this, or am I barmy?
    PS I'm using and defining a 20Mhz osc but have tried with same results on 4 and 8 Mhz
    Some rational explanation would be greatly appreciated!
    adrian
    Hmmm, I'm not sure Adrian.
    I've double checked it here on a 16F88 and I can go up to 12khz with a 20mhz OSC. Or 25khz by changing the Handler's "TYPE" to ASM.
    I did find some inaccuracy in the math,
    This line ...
    TimerReload = MaxCount - ((25000 / Freq) * (OSC*10/Prescaler))
    Should be like this...
    TimerReload = MaxCount - OSC*1000000/4/Prescaler/Freq
    but that shouldn't cause what you've described.
    Which PIC are you using?
    May 2007
    Suffolk, UK
    Default Reply to Darrel's query
    I'm using the ubiquitous 16F877A. Using the time difference between you and the UK I will change the maths anyway and try different frequencies again. I will also double check everything on the development board and will report back...!! Did you try with TOGGLE in the TIHandler? I wondered if that instruction was somehow slowing it down. Thank you for your help...this is bugging me!
    Adrian
  1. PTO Generator
    By b1arrk5 in forum Off Topic
    Last Post: - 25th November 2013, 14:25
  2. 2 Beam Optical Pulse Generator
    By WOZZY-2010 in forum Schematics
    Last Post: - 6th April 2010, 04:03
  3. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 20:02
  4. Frequency Generator
    By ExYu in forum Off Topic
    Last Post: - 22nd January 2008, 18:25
  5. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
