EM4095 Chip, get Clock and Data signals?
Results 1 to 15 of 15
    Mar 2008
    Thanks.
    Also, when you say that Variable are global, then if you look at the mikroBasic code, then you would see that there are some variables made in the main section and also in a Procedure some variables are made, which can only be used in that Procedure!
    So what about them?
    Quote Originally Posted by mindthomas View Post
    Thanks.
    So what about them?
    Use different variables.
    Mar 2008
    So you mean that i should make them Global too, as there aren't anything UnGlobal in PBP?
    I mean if they are truly global, then they are the same variable thru the program.
    If they aren't, then the variable most likely has two different meanings in different, distinct functions/modules/subroutines.
    In PBP, all variables are global, meaning that if temp holds a value here, it holds that same value over there, and over there, and over here.
    Mar 2008
    Okey, thanks.
    Could you help me with some more, especially the Interrupt, or if it could be done without using Interrupt!! (it could be great if it could be done without)
    Okey, thanks.
    Doubt it...
    Okey, thanks.
    Doubt it...
    Doubt what?
    That it can be done without interrupts?
    Or that you could help him?
  1. Data Out From External Clock
    By Quin in forum Serial
    Last Post: - 25th October 2008, 09:11
  2. Data logger clock and array
    By PicLearner in forum mel PIC BASIC Pro
    Last Post: - 25th September 2008, 04:19
  3. Shiftout/in
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2007, 11:48
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  5. MAX1247 4-Channel, 12-Bit ADC
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 15th December 2006, 23:38
