Newbie with photoresistor problem
Results 1 to 11 of 11
    Karthik's Avatar
    Karthik Guest
    Red face Newbie with photoresistor problem
    The following is a very simple circuit that uses a photoresistor as a switch to run a motor using a battery pack. But for some reason no matter how much light i expose the photoresistor to it does no conduct. The general resistance without any light is 200, 000 ohm. and using a torch it is 440 ohm. HELP.
    Quote Originally Posted by Karthik View Post
    | Photoresistor
    Battery |
    Pack |
    | Motor
    Most assuredly NOT the way to run a motor using a photoresistor. Sounds real good in theory for somebody that doesn't know any better, but still, not the way to do it.
    You might be wanting to use a phototransistor to do this job. But again, not the best way to do the job.
    And how does this tie in to PicBasic?
    Default LDR is a SENSOR - not a controller
    The Light Dependent Resistor is a sensor. Its resistance is way too high to drive any conventional low cost motor. In darkness the LDR will be several megohms. In bright light it will be under 1000 ohms, depending on make and model.
    You need to measure the LDR with either the POT command or an ADC and then convert that to a PWM signal to drive the motor.
    HTH
    BrianT
    Jan 2006
    Istanbul
    Here is a sample circuit to drive a dc motor with a(n) LDR.
    Works in simulation at least!
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2817&stc=1&d=121878587 6" >
    Feb 2010
    Default Seems to work in reverse
    Quote Originally Posted by sayzer View Post
    Sayzer, thanks for posting the schematic.
    I too need to turn on a motor with a LDR, however, when I made the circuit as diagramed, it works in reverse. It turns the motor on in light, and off in darkness.
    Does anyone know what do I need to do to make the motor turn on in darkness, and off in light?
    thanks
    Flip LDR and R1???
    Mar 2015
    Default Re: Seems to work in reverse
    How much voltage do I apply for running that motor?
  1. Newbie making an ignition timer
    Last Post: - 5th August 2012, 17:45
  2. Newbie HELP :(
    By TheOne in forum mel PIC BASIC
    Last Post: - 27th March 2009, 17:15
  3. Newbie: Temperature measurements
    By Budda in forum General
    Last Post: - 30th March 2007, 09:56
  4. PIC Newbie
    By azmax100 in forum Schematics
    Last Post: - 23rd February 2007, 04:52
  5. request for a newbie forum
    By nimonia in forum Forum Requests
    Last Post: - 20th May 2006, 09:01
