I ve been trying to solve this for like a month. Finally i got here.I am trying to create new hex file from below code but PIC16 Simulator IDE has given these errors.I've looked everywhere couldn't find anything. Pleas help me to solve this problem . Thank you.
; mclock8.asm
; "The Propeller" mechanically scanned LED clock
; some changes since last version -
; modified table etc for compatiblility with 8th LED
; watchdog timer used to ensure startup
; Bob Blick February 12, 1997
; Licensed under the terms of the GNU General Public License, www.gnu.org
; No warranties expredded or implied
; Bob Blick February 18, 2002
        list    p=16f84a
        radix    hex
        #include    <"p1f84a.inc">
; remember to set blast-time options: OSC=regular xtal, WDT=ON
; timings all based on 4 MHz crystal
; are these equates already in the include file? someday I'll look.
    " w    equ     0    ;"
    " f    equ     1    ;"
; Start of available RAM.
cblock
safe_w        ;not really temp, used by interrupt svc
safe_s        ;not really temp, used by interrupt svc
period_count    ;incremented each interrupt
period_dup    ;copy of period_count safe from interrupt
period_calc    ;stable period after hysteresis calc.
flags        ;b2=int b1=minute b4=edge
dot_index    ;which column is being displayed
digit_index    ;which digit is being displayed
hours        ;in display format, not hex(01-12)
minutes        ;00 to 59
bigtick_dbl    ;incremented each interrupt
bigtick_hi
bigtick_lo
keys        ;key value
scratch        ;scratch value
tick        ;used by delay
endc
; Start of ROM
        org    0x00        ;Start of code space
        goto    Start
; INTERRUPT SERVICE ROUTINE
        org    0x04        ;interrupt vector
Intsvc    movwf    safe_w        ;save w
        swapf    STATUS,w    ;swap status, w
    movwf    safe_s        ;save status(nibble swap, remember)
; done saving, now start working
; clear watchdog timer to ensure startup
        clrwdt
; increment period count
    incf    period_count,f
        btfsc    STATUS,Z    ;zero set means overflow
    decf    period_count,f
; 234375 interrupts every minute. Increment the bigtick each time.
        incf    bigtick_lo,f
        btfsc    STATUS,Z
        incf    bigtick_hi,f
        btfsc    STATUS,Z
        incfsz    bigtick_dbl,f
        goto    Bigtick_out
; here? bigtick has rolled over to zero and one minute has passed.
; reload bigtick and set a flag for the main counter
        movlw    0xFC        ;234375 = 0x039387
        movwf    bigtick_dbl    ;0 - 0x039387 = 0xFC6C79
        movlw    0x6C
        movwf    bigtick_hi
        movlw    0x79
        movwf    bigtick_lo
        bsf    flags,1        ;notify Keep_time
Bigtick_out
; done working, start restoring
        swapf    safe_s,w    ;fetch status, reswap nibbles
        movwf    STATUS        ;restore status
        swapf    safe_w,f    ;swap nibbles in preparation
        swapf    safe_w,w    ;for the swap restoration of w
        bcf    INTCON,2    ;clear interrupt flag before return
        retfie            ;return from interrupt
; CHARACTER LOOKUP TABLE
; ignore high bit. set=LED off, clear=LED on, bit0=bottom LED, bit6=top LED
Char_tbl
        addwf    PCL,f
     "dt    0xC1,0xBE,0xBE,0xBE,0xC1    ; "O" ;
     "dt    0xFF,0xDE,0x80,0xFE,0xFF    ; "1" ;
    " dt    0xDE,0xBC,0xBA,0xB6,0xCE    ; "2" ;
    " dt    0xBD,0xBE,0xAE,0x96,0xB9    ; "3" ;
    " dt    0xF3,0xEB,0xDB,0x80,0xFB    ; "4" ;
    " dt    0x8D,0xAE,0xAE,0xAE,0xB1    ; "5" ;
     "dt    0xE1,0xD6,0xB6,0xB6,0xF9    ; "6" ;
     "dt    0xBF,0xB8,0xB7,0xAF,0x9F    ; "7" ;
     "dt    0xC9,0xB6,0xB6,0xB6,0xC9    ; "8" ;
     "dt    0xCF,0xB6,0xB6,0xB5,0xC3    ; "9" ;
     "dt    0xFF,0xC9,0xC9,0xFF,0xFF    ; ":" ;
Char_tbl_end
; SUBROUTINES STARTING HERE
; clear important bits of ram
Ram_init    movlw    0x07
        movwf    keys
        movlw    0x12        ;why do clocks always start
        movwf    hours        ;at 12:00 ?
        clrf    minutes
        clrf    dot_index
        clrf    digit_index
        movlw    0xFC
        movwf    bigtick_dbl
        retlw    0
; unused pins I am setting to be outputs
Port_init    movlw    0x00        ;all output, b7=unused
        tris    PORTB        ;on port b attached to LEDs
        movlw    b'00010111'    ;port a has 5 pins. I need 4 inputs
                    ;b0=minutes, b1=10mins, b2=hours
                    ;b3=unused, b4=rotation index
        tris    PORTA        ;on port a
        retlw    0
; get timer-based interrupts going
Timer_init    bcf    INTCON,2    ;clear TMR0 int flag
        bsf    INTCON,7    ;enable global interrupts
        bsf    INTCON,5    ;enable TMR0 int
        clrf    TMR0        ;clear timer
        clrwdt            ;why is this needed? just do it..
        movlw    b'11011000'    ;set up timer. prescaler(bit3)bypassed
        option            ;send w to option. generate warning.
        clrf    TMR0        ;start timer
        retlw    0
; test for index in rotation and store period in period_dup
Check_index    movf    PORTA,w        ;get the state of port a
        xorwf    flags,w        ;compare with saved state
        andlw    b'00010000'    ;only interested in bit 4
        btfsc    STATUS,Z    ;test for edge
        retlw    0        ;not an edge, same as last
        xorwf    flags,f        ;save for next time
        btfsc    flags,4        ;test for falling edge
        retlw    0        ;must have been a rising edge
        movf    period_count,w    ;make a working copy
        movwf    period_dup    ;called period dup
        clrf    period_count    ;a fresh start for next rotation
        clrf    digit_index    ;set to first digit
        clrf    dot_index    ;first column
; calculate a period that does not dither or jitter
; period will not be changed unless new period is really different
         movf    period_calc,w
        subwf    period_dup,w    ;find difference
        btfss    STATUS,C    ;carry flag set means no borrow
        goto    Calc_period_neg    ;must be other way
        sublw    2        ;allowable deviation = 3
        btfss    STATUS,C    ;borrow won't skip
        incf    period_calc    ;new value much larger than calc
        retlw    0
Calc_period_neg    addlw    2        ;allowable deviation = 3
        btfss    STATUS,C    ;carry will skip
        decf    period_calc    ;no carry means it must be changed
        retlw    0
; change LED pattern based on state of digit_index and dot_index
Display_now    movlw    0x05
        xorwf    dot_index,w    ;test for end of digit
        movlw    0xFF        ;pattern for blank column
        btfsc    STATUS,Z
        goto    D_lookup_3    ;it needs a blank
        bcf    STATUS,C    ;clear carry before a rotate
        rlf    digit_index,w    ;double the index because each
        addwf    PCL,f        ;takes two instructions
D_10hr        swapf    hours,w
        goto    D_lookup    ;what a great rush of power
D_1hr        movf    hours,w        ;I feel when modifying
        goto    D_lookup    ;the program counter
D_colon        movlw    0x0A
        goto    D_lookup
D_10min        swapf    minutes,w
        goto    D_lookup
D_1min        movf    minutes,w
        goto    D_lookup
D_nothing    retlw    0
D_lookup    andlw    b'00001111'    ;strip off hi bits
        movwf    scratch        ;multiply this by 5 for lookup
        addwf    scratch,f    ;table base position
        addwf    scratch,f    ;is this cheating?
        addwf    scratch,f    ;I think not.
        addwf    scratch,f    ;I think it is conserving energy!
        btfss    STATUS,Z    ;test for zero
        goto    D_lookup_2    ;not a zero
        movf    digit_index,f    ;this is just to test/set flag
        movlw    0xFF        ;this makes a blank LED pattern
        btfsc    STATUS,Z    ;test if it is 10 hrs digit
        goto    D_lookup_3    ;it's a leading zero
D_lookup_2    movf    dot_index,w    ;get column
        addwf    scratch,w    ;add it to digit base
        call    Char_tbl    ;get the dot pattern for this column
D_lookup_3    movwf    PORTB        ;send it to the LEDs
        movlw    0x0C        ;overhead value sub from period
        subwf    period_calc,w    ;compensate for overhead and set
        call    Delay        ;width of digits with this delay
        incf    dot_index,f    ;increment to the next column
        movlw    0x06        ;6 columns is a digit plus space
        xorwf    dot_index,w    ;next digit test
        btfss    STATUS,Z
        retlw    0        ;not a new digit
        clrf    dot_index    ;new digit time
        incf    digit_index,f
        retlw    0        ;Display_now done.
; a short delay routine
Delay        movwf    tick
Delay_loop    decfsz    tick,f
        goto    Delay_loop    ;w is not damaged, so Delay can
        return            ;be recalled without reloading
; test for keypress and call time adjust if needed
Check_keys    movf    PORTA,w        ;get port "a"
        xorwf    keys,w        ;compare with previous
        andlw    b'00000111'    ;only care about button pins
        btfsc    STATUS,Z    ;zero set=no buttons
        retlw    0        ;return
        xorwf    keys,f        ;store key value
        movlw    0x64        ;a fairly long delay will
        movwf    scratch        ;prevent key bounces
Key_delay    movlw    0xFF
        call    Delay
        decfsz    scratch
        goto    Key_delay
        btfss    keys,2        ;test "minutes" button
        goto    Inc_mins
        btfss    keys,1        ;test "tens" button
        goto    Inc_tens
        btfss    keys,0        ;test "hours" button
        goto    Inc_hours
        retlw    0        ;must be a glitch. yeah, right!
; increment ten minutes
Inc_tens    movlw    0x0A
        movwf    scratch        ;scratch has ten
Inc_tens_loop    call    Inc_mins
        decfsz    scratch
        goto    Inc_tens_loop    ;another minute added
        retlw    0
; increment one hour
Inc_hours    movlw    0x12
        xorwf    hours,w
        btfsc    STATUS,Z
        goto    Inc_hours_12
        movlw    0x07        ;this part gets a little sloppy
        addwf    hours,w
        movlw    0x07
        btfss    STATUS,DC
        movlw    1
        addwf    hours,f
        retlw    0
Inc_hours_12    movlw    0x01
        movwf    hours
        retlw    0
; increment the time based on flags,1 as sent by interrupt routine
; Inc_mins loop also used by time-setting routine
Keep_time    btfss    flags,1        ;the minutes flag
        retlw    0        ;not this time
        bcf    flags,1        ;clear the minutes flag
Inc_mins    movlw    0x07        ;start incrementing time
        addwf    minutes,w    ;add 7 minutes into w
        btfsc    STATUS,DC    ;did adding 7 cause digit carry?
        goto    Sixty_mins    ;then test for an hour change
        incf    minutes        ;otherwise add 1 for real
        retlw    0        ;and go back
Sixty_mins    movwf    minutes        ;save the minutes
        movlw    0x60        ;test for 60
        xorwf    minutes,w    ;are minutes at 60?
        btfss    STATUS,Z
        retlw    0        ;no? go back
        clrf    minutes        ;otherwise zero minutes
        goto    Inc_hours    ;and increment hours
; End of subroutines
; Program starts here
Start        call    Ram_init    ;set variables to nice values
        call    Port_init    ;set port directions
        call    Timer_init    ;start timer based interrupt
; Done initializing, start the endless loop.
Circle                    ;begin the big loop
; detect falling edge on PORTA,4 to determine rotary index
; calculate rotation period and store in period_dup
; compare with working period(period_calc) and adjust if way different
        call    Check_index
; check display state and change if needed
        call    Display_now
; check keyboard and adjust time
        call    Check_keys
; check minute flag and increment time if a minute has passed
        call    Keep_time
; gentlemen, that's a clock, keep it rolling
        goto    Circle        ;you heard the man, get going!
; end of file
mclock8.txt This is the original of the code.
