Changing bits in a byte for multiple output
Results 1 to 4 of 4
    Default Changing bits in a byte for multiple output
    Hello,
    I've been playing with this project for sometime and a lot of ya'll have been a great help.
    I am trying to get my transmitter side working and I would like to be able to press more than one button at a time to get multiple outputs to come on if needed. with the below example everything works fine, one button at a time and If I press the button the output stays on until I release the button but if I press more than one button everything comes on and goes off and acts crazy:
    INCLUDE "MODEDEFS.BAS"
    @ DEVICE PIC16F628a,XT_OSC
    @ DEVICE pic16F628a, WDT_OFF
    @ DEVICE pic16F628a, PWRT_ON
    @ DEVICE pic16F628a, MCLR_ON
    @ DEVICE pic16F628a, BOD_ON
    @ DEVICE pic16F628a, LVP_OFF
    @ DEVICE pic16F628a, CPD_OFF
    @ DEVICE pic16F628a, PROTECT_OFF
    define osc 4
    CMCON=%00000111
    trisb = %11111111
    trisa = %00010111
    chk_sum var byte
    dgood var porta.2
    serpin var porta.3
    nokey con %11111111
    synch con 254
    address con %00000001
    keyin var portb
    keydata var byte
    E VAR PORTB.0
    D VAR PORTB.1
    G VAR PORTB.2
    A VAR PORTB.3
    B VAR PORTB.4
    C VAR PORTB.5
    F VAR PORTB.6
    na VAR PORTB.7
    keydata1 var byte
    PreAmble CON $A5
    findkey:
    if A = 0 then
    keydata.1=1
    keydata.2=1
    keydata.4=1
    keydata.6=1
    if B = 0 then
    keydata.0=1
    keydata.3=1
    keydata.4=1
    keydata.6=1
    if C = 0 then
    keydata.1=1
    keydata.3=1
    keydata.4=1
    keydata.6=1
    if D = 0 then
    keydata.0=1
    keydata.2=1
    keydata.5=1
    keydata.6=1
    if E = 0 then
    keydata.1=1
    keydata.2=1
    keydata.5=1
    keydata.6=1
    if F = 0 then
    keydata.0=1
    keydata.3=1
    keydata.5=1
    keydata.6=1 s
    if G = 0 then
    keydata.1=1
    keydata.3=1
    keydata.5=1
    keydata.7=1 s
    keydata1=keydata
    low dgood
    chk_sum = (address + address)
    chk_sum = chk_sum + (keydata + keydata)
    serout serpin,N2400,[$55,$55,$55,$55,$55,$AA,$AA,$AA,$AA,$AA,synch,addr ess,address,keydata1,keydata1,chk_sum]
    if keyin = nokey then x2
    goto findkey
    x2:
    high dgood
    keydata1 = %00000000
    keydata = %00000000
    goto findkey
    If I do it like this:
    define osc 4
    CMCON=%00000111
    trisb = %11111111
    trisa = %00010111
    chk_sum var byte
    dgood var porta.2
    serpin var porta.3
    nokey con %11111111
    synch con 254
    keyin var portb
    keydata var byte
    E VAR PORTB.0
    D VAR PORTB.1
    G VAR PORTB.2
    A VAR PORTB.3
    B VAR PORTB.4
    C VAR PORTB.5
    F VAR PORTB.6
    na VAR PORTB.7
    PreAmble CON $A5 ' 10100101 preamble
    findkey:
    if A = 0 then sw0
    if B = 0 then sw1
    if C = 0 then sw2
    if D= 0 then sw3
    if E = 0 then sw4
    if F = 0 then sw5
    if G = 0 then sw6
    goto findkey
    sw0:
    keydata = %01010110
    goto dout
    sw1:
    keydata = %01011001
    goto dout
    sw2:
    keydata = %01011010
    goto dout
    sw3:
    keydata = %01100101
    goto dout
    sw4:
    keydata = %01100110
    goto dout
    sw5:
    keydata = %01101001
    goto dout
    sw6:
    keydata = %01101010
    goto dout
    dout:
    low dgood
    goto transmit
    transmit:
    serout serpin,N2400,[$55,$55,$55,$55,$55,$AA,$AA,$AA,$AA,$AA,synch,addr ess,address,keydata,keydata,chk_sum]
    goto findkey
    x2:
    high dgood
    keydata = %00000000
    goto findkey
    Then the output selected on the receiver will come on and stay on until I press the next button in which the first output goes off and the second comes on, and so on. So what is the difference between just changing a bit in the byte and sending it serially or changing the whole byte each time? Is there a better way to detects several buttons pressed at the same time and then send the data out?
    You're making this WAYYYY too hard.
    If you've got all of the keys on portB, then just send the whole portB value, all 8 bits, all the keys, all at once, and keep sending them. Even if you don't have all of the buttons on PortB, get all of the buttons states and put them into the bits of a single byte variable and send that.
    Get that working so it's infallible, or at least as infallible as you can tolerate it.
    Then do all of the hard work at the receiver end figuring out which lights to light or whatever.
    I'm thinking you won't get anywhere until that happens...
    Thanks Skimask, your right I have made this difficult but the reason I was not sending out the whole PORTB is that I am trying to use a simple manchester encoding. My 0 is a 01 an a 1 being 10.
    Quote Originally Posted by tazntex View Post
    I don't think I would worry about encoding anything at the moment. You're sending short packets. As long as you've got preamble and a sync'ing character, you should be good to send the raw port data, in short bursts anyways.
    i.e. SEROUT datapin , mode , whatever , $55,$AA,$FE,raw_portb_data (assuming portb.7 isn't actually used)
    Just keep resending it as long as a key is pressed and code the receiver to look for the same thing that you're sending.
    Last Post: - 14th June 2016, 07:55
  2. byte compression
    By Norbert in forum mel PIC BASIC Pro
    Last Post: - 16th June 2007, 18:04
  3. Serious Serial Situation Setbacks...
    Last Post: - 7th February 2007, 03:46
  4. 16F877 RAM Question
    By Art in forum mel PIC BASIC Pro
    Last Post: - 6th August 2005, 11:47
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 14:31
