Portb 16F628A
Results 1 to 9 of 9
Thread: Portb 16F628A
    Default Portb 16F628A
    This may sound like a really dumb question or I have a bad lot of processors, I doubt that but the question is can I do this:
    myvar var byte
    portb = myvar
    And whatever myvar is, really it is a binary number, the ports pins on portb would change to that state.
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by tazntex View Post
    myvar var byte
    portb = myvar
    As long as all pins on PORTB are set to OUTPUTs, which they're not upon RESET...on most, if not all, PICs, as noted in most, if not all, datasheets, in the 'I/O Ports' section, and as long as said pins are not designated for another use (i.e. PortA, analog vs. digital usage).
    He means yes . . .
    skimask,
    you are starting to sound like a lawyer
    Question
    The problem with Lawyers is that you never really know what they said.
    See, I thought ski said YES, with "as long as certain conditions were met" added.
    But since it can't work with ONLY the code being shown. Maybe his answer was really NO.
    <br>
    It is that little bit of doubt that makes one wonder
    I need to go find something to do...
  1. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 19:52
  2. shifting problem
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 06:11
  3. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 20:10
  4. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 5th May 2005, 23:29
  5. Help wanted..
    By thrix in forum mel PIC BASIC Pro
    Last Post: - 17th February 2004, 23:44
