Winbond ISD1700 Voice Recorder
Results 1 to 40 of 59
    Mar 2009
    Default Updated Design Guide
    RFEFX,
    I'm actually using a later version of the design guide. If you or anyone for that matter wants a later version, send me a PM with your email and I can email you the PDF.
    Alan
    I have version 1.31, Nov. 6, 2008.
    Mar 2009
    Default Getting Close But Not Quite There
    Hey Guys,
    I'm getting close but I'm not quite there. I have the audio chip recording and playing because the LED is constant during recording and blinks during playing. But unfortunately I'm not getting anything out of the speaker except a small hum. I've documented my setup of what I'm doing below. I'm a little bit unfamiliar with audio signals so its certainly possible that I might be doing something wrong.
    I'm using the audio in pin which has a 0.1uF cap on it as recommended in the datasheet. Once powered up in SPI mode, the ISD17000 should assumes that the audio input is from this pin and not the microphone, (If I read the design guide correctly). I'm trying to put a simple audio output signal from my PC tower into this pin. I cut off the end of a wire that has an audio jack on the one end. There was a red wire and a white wire inside that I stripped down to the wire. I tested the output audio signals with an oscilloscope and they're between +/- 1 Volt. I didn't think it mattered which wire I soldered to the audio input pin on my board because as far as I know audio is just a differential signal, right? But currently the white wire is soldered to the input pin. And I tied the red wire to ground. I even monitored the input signals here as I recorded them and saw the input on the oscilloscope. But when I go to play back the recording, the speaker just hums as if there was only a very faint sound.
    Does anybody know what I'm doing wrong? Any suggestions for troubleshooting? I'm not sure what to check next.
    Thanks, Alan
    Mar 2009
    Well I actually figured out 2 things. 1) The analog input is not a factory default. Bit 6 of the APC register should be cleared to use the analog input. 2) If you enable the visual LED aid during recording or playing and do a read status command without the LED bit enabled, the LED will stop even if it continues to read or write. Learned that lesson in about 5 hours earlier today.
    Alan
    Have a look at this:
    http://www.4dsystems.com.au/prod.php?id=73
    Almost unlimited messages!
    spolk10's Avatar
    spolk10 Guest
    Default Re: Getting Close But Not Quite There
    Quote Originally Posted by ams0178 View Post
    Hey Guys,
    Thanks, Alan
    Alan,
    I am having the same problem. What did you do to fix this?
    Scott
    Omaha, Nebraska USA
    Mine is Rev. 0, October 2006.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Nov 2006
    Murrieta, CA
    Default 4dsystems
    Yeah Ioannis,
    i saw that audio module a while back .. i will be ordering one soon and posting my project here... i do have several Oled displays from them as well... they make very well designed products and i do recommend them.
    - RFEFX
    There are 10 kinds of people. Those that know binary and those that do not.
    I will be looking forward in reading your review of the product.
    Please do post your results on this.
  1. ISD1700 series Winbond chipcorder
    By rickeybell in forum mel PIC BASIC Pro
    Last Post: - 21st March 2010, 06:13
  2. optical voice link
    Last Post: - 18th May 2008, 21:11
  3. Voice CODEC
    By Ron Marcus in forum Off Topic
    Last Post: - 15th May 2005, 19:28
