Winbond ISD1700 Voice Recorder
Results 1 to 40 of 59
    Nov 2006
    Murrieta, CA
    Default Finally !!! Complete !
    Thanks everyone for helping me understand this device and the steps to get it coded. i have been playing with it all day recording messages and playing them back.
    Thanks Jerson, Brenon and Jim for simplifying and breaking it down so that i may understand it line by line. my problem i was using the SHIFTOUT commands in PBP and i was not working properly. i now know how much memory space i need for the 20, 1 to 4 second sounds that i will be using.
    Cheers to all of you... today is a good day.
    - Gary
    There are 10 kinds of people. Those that know binary and those that do not.
    Bombay, India
    Hi Gary
    Good to know you have figured it out. You have yourself to thank for the patience and dedication to figure it out.
    Thanks Jim for the tips. OK, I will try a bit more without beeing prejudiced.
    Gary: If you areallowed can you post the working code?
    Nov 2006
    Murrieta, CA
    Default Ok... here's the code
    hey Ioannis,
    here is my code that I have working. I am using my own RFEFX board which includes an RF. If you have any questions please don't hesitate to ask. after i cleaned up some of Jim's code, as I have a different platform, the lights kinda just went off in my head and it all became real easy. For Video Click Here (9MB File takes a min to load)
    '*  Name    : ISD17XX.BAS
    '*  Authors : Jerson,Brenon,Jim,Gary
    define OSC 20
    Time1 var word          'these variables used for the Erase flash
    Time2 var byte          'LEDS when the device is erased
                            'used in Label - FlashLED:
    time1 = 5000
    time2 = 50
    '******************** DEFINE VARIABLES ***********************
    temp_bit    VAR BIT
    temp		VAR BYTE
    spi_cnt 	var byte	' counter for SPI transfer
    bSPI 		var byte 	' the byte being transferred on SPI
    s_addr		VAR WORD	' Start Address
    e_addr		VAR WORD	' End Address
    ISD_Data 	var byte[7]	' This array contains data to/from ISD
    SR0a 		var ISD_Data[0]
    SR0b 		var ISD_Data[1]
    SR1 		var ISD_Data[2]    ' only valid after ReadStatus
    isCmdErr 	var SR0a.0	' 1=previous command failed/ignored
    isFull 		var SR0a.1	' 1=memory full
    isPU		var SR0a.2	' 1=ISD powered up
    isEOM		VAR SR0a.3	' 1=EOM detected (clear by CLR_INT command)
    isINT 		var SR0a.4	' 1=current operation completed (clear by CLR_INT command)
    isReady 	var SR1.0	' 1=Ready to receive SPI command (only valid after ReadStatus)
    				        ' Some SPI commands can still be sent when isReady=0
    '******************** PIN ASSIGNMENTS ************************
    Symbol miso		= PORTC.5			'ISD1760 SPI MISO
    Symbol LED1	    = PORTA.5			'
    Symbol LED2	    = PORTA.0			'
    Symbol ss		= PORTC.7			'ISD1760 SLAVE SELECT
    Symbol sclk		= PORTC.4			'ISD1760 SPI CLOCK
    Symbol mosi 	= PORTC.6         	'ISD1760 SPI MOSI
    '******************** INITIALIZATION *************************
    initialize:
      ' Im using a PIC 16F876A with an external 20 MHZ clock
      ' there is really little setup.
    	HIGH ss			'start with Slave Select HIGH
    	HIGH sclk		'start with SPI Clock HIGH
    	LOW  MOSI		'start with MOSI LOW
    	LOW LED1
    	LOW led2
    start:                       'Initialize the ISD
    	GoSub isd_pu
    	PAUSE 50		         '50 mS Power Up Delay (per datasheet)
           'I removed the APC because it doesn't work on my Audio Board
    	PAUSE 10
    	GoSub isd_clr_int	     'clear interrupt and EOM
    	gosub erase              'this will erase the ISD chip whenever
    	                         'I reprogram my PIC
    '********************* MAIN PROGRAM **************************
    main_loop:	'(MAIN PROGRAM LOOP)
        PAUSE 2000
    RecordLoop:                       'Here is my board waiting for me to
        if portc.3 = 1 then Record       'push the record button
        goto recordLoop
    Record:
        high led1                   'a record LED
        if portc.3 = 1 then record  'it will not continue until i
                                       'release the button
        s_addr = $010               'a 1 second clip takes approx 16 rows of
        e_addr = $01f               'memory space $010-$01F = 16
        GOSUB isd_set_rec           'this Set_rec identical to set_play
                                    'was added so i could record a message
        PAUSE 2000
        GOSUB isd_stop              ' an immediate stop to stop recording
        low led1                    ' turn record LED off
    Playloop:                       'the same button then becomes a play button
        'pause 2000
        if portc.3 = 1 then play
        goto playloop
    Play:
        high led2                   'a different LED for play
        if portc.3 = 1 then play    'wont play until button is released
        s_addr = $010               'playing back from the same 16 rows
        e_addr = $01f
        GOSUB isd_set_play
        PAUSE 2000
        GOSUB isd_stop
        low led2
    Eraseloop:
        'pause 2000
        if portc.3 = 1 then play     'in this loop you can either play the sound
        if portc.5 = 1 then erase    'again or erase it and record another one
        goto Eraseloop               'two different buttons are used
    Erase:                           'this is the erase subroutine which is also
        if portc.5 = 1 then erase    'called at the beginning of this program
        s_addr = $010                'this is not a Gang erase so the Start and
        e_addr = $01f                'End address must be present or you will get
        GOSUB isd_set_erase          'a command error
        gosub flashLED               'when i erase the chip a series of LEDS
                                     'are flased to indicate an erase.
        goto recordloop              'after an erase it goes back to record loop
    '********************** SUBROUTINES **************************
    isd_pu:
    	LOW ss
    	bSPI=$01		'Power Up Command
    	GoSub isd_spi
    	ISD_Data[0] = bSPI 	'SR0a
    	bSPI=$00
    	GoSub isd_spi
    	ISD_Data[1] = bSPI 	'SR0b
    	HIGH ss
    isd_wait_ready:
    	GOSUB isd_rd_status
    	IF isReady = 0 THEN isd_wait_ready
    isd_set_play:
    	LOW ss
    	bSPI = $80		'Set Play Command (7 bytes)
    	GoSub isd_spi
    	bSPI = $00
    	GoSub isd_spi
    	bSPI = s_addr.LowByte 	' Start Address low byte.
    	GoSub isd_spi
    	ISD_Data[2] = bSPI	'SR0a
    	bSPI = s_addr.HighByte 	' Start Address high byte
    	GoSub isd_spi
    	ISD_Data[3] = bSPI 	'SR0b
    	bSPI = e_addr.LowByte 	' End Address low byte
    	GoSub isd_spi
    	ISD_Data[4] = bSPI 	'SR0a
    	bSPI = e_addr.HighByte 	' End Address high byte
    	GoSub isd_spi
    	ISD_Data[5] = bSPI 	'SR0b
    	bSPI = $00		' Reserved Address - set to "0"
    	GoSub isd_spi
    	ISD_Data[6] = bSPI 	'SR0a
    	HIGH ss
    isd_Set_Erase:
    	LOW ss
    	bSPI = $82		           'Set Erase Command (7 bytes)
    	GoSub isd_spi
    	ISD_Data[0] = bSPI	        SR0a
    	bSPI = $00
    	GoSub isd_spi
    	bSPI = s_addr.LowByte 	   'Start Address low byte.
    	GoSub isd_spi
    	bSPI = s_addr.HighByte 	   'Start Address high byte
    	GoSub isd_spi
    	bSPI = e_addr.LowByte 	   'End Address low byte
    	GoSub isd_spi
    	bSPI = e_addr.HighByte 	   'End Address high byte
    	GoSub isd_spi
    	bSPI = $00		           'Reserved Address - set to "0"
    	GoSub isd_spi
    	HIGH ss
    isd_set_rec:
    	LOW ss
    	bSPI = $81		           'Set Record Command (7 bytes)
    	GoSub isd_spi
    	bSPI = $00
    	GoSub isd_spi
    	GoSub isd_spi
    	GoSub isd_spi
    	GoSub isd_spi
    	GoSub isd_spi
    	GoSub isd_spi
    	HIGH ss
    isd_spi:				        ' shift SPI data out and into SPI byte
    	FOR spi_cnt = 0 to 7        '
    		MOSI = bSPI.0 		    ' shift LSB of byte onto MOSI line
    		LOW SCLK 		        ' clock MISO data out to uC (Falling Edge)
    		temp_bit = miso         '
    		HIGH SCLK		        ' clock MOSI into ISD1700 (Rising Edge)
    		bSPI = bSPI >> 1 		' shift SPI byte Right
    		bSPI.7 = temp_bit
    	NEXT spi_cnt
    isd_clr_int:					' CLEAR INTERRUPT AND EOM BITS
    	LOW SS
    	bSPI=$04		            'Clear Interrupt Command
    	gosub isd_spi
    	bSPI=$00
    	gosub isd_spi
    	HIGH SS
    isd_stop:					 ' Stop Immediately
    	LOW ss
    	bSPI=$02		         'Stop Command
    	gosub isd_spi
    	bSPI=$00
    	gosub isd_spi
    	HIGH ss
    isd_rd_status:				'read status of ISD1700
    	LOW ss                  '
    	bSPI=$05		        'Read Status Command
    	gosub isd_spi
    	bSPI=$00
    	gosub isd_spi
    	bSPI=$00
    	gosub isd_spi
    	ISD_Data[2] = bSPI	    'SR1
    	HIGH ss
    '*********** Erase Indicators ********************************
    FlashLED:
        pulsout porta.5,time1
        pause time2
        pulsout porta.3,time1
        pause time2
        pulsout porta.2,time1
        pause time2
        pulsout porta.1,time1
        pause time2
        pulsout porta.0,time1
        pause time2
        low porta.0
    Hi Gary.
    Thanks a lot for your sample code.
    Nice work with the pcb's too!
    Your video was downloaded in less than 9 sec, for the records.
    Also your introduction to the site is quite impressive. Waiting to see the rest! Did you do this your own?
    Nov 2006
    Murrieta, CA
    Hey Ioannis,
    Thanks a lot for your feedback. I do understand Flash websites, but in all honesty, it took
    me 5 hours modifying that flash intro template to my liking. i couldnt imagine coding the
    entire thing from scratch. Although "If there is a will. There is a way."
    The website will be based on the same flash template arcitecture and i cant imagine how long
    that is going to take me to modify.
    But yeah, thanks for the feed back and I hope you like the site when its available...
    - Gary
    Hi Gary.
    1. Do you have any newer design guide for the ISD17xx than the revision 0/2006?
    2. What do you use for the site you built? Is this template included?
  1. ISD1700 series Winbond chipcorder
    By rickeybell in forum mel PIC BASIC Pro
    Last Post: - 21st March 2010, 06:13
  2. optical voice link
    Last Post: - 18th May 2008, 21:11
  3. Voice CODEC
    By Ron Marcus in forum Off Topic
    Last Post: - 15th May 2005, 19:28
