Winbond ISD1700 Voice Recorder
Results 1 to 40 of 59
    Jun 2007
    Quote Originally Posted by milestag View Post
    I did some further testing. Seems the best way to determine when a sound has finished playing is to monitor the INT status bit. Just remember to clear the INT before each SET_PLAY...
    So monitoring the Int bit - reads 0 when the file is playing and sets to 1 when completed... I have completed the program for this chip in my application! : INSERT BOUNCY HERE:
    I'd REALLY like to thank Jerson for the initial beginning of this coding and to thank Jim for the clarifications needed to succeedingly write the final piece to operate my products.
    Brenon
    Last edited by ivirscar; - 8th February 2009 at 21:53. Reason: Clarification of post...
    Jan 2014
    Default Re: Winbond ISD1700 Voice Recorder
    I tried to play a recorded sound on ISD1730 but something is wrong. I use 16F1503 set at 4 MHZ. Can somebody help me..? Thx in advance
    CODE:
    __config _CONFIG1, _FOSC_INTOSC & _MCLRE_OFF & _CP_ON & _CLKOUTEN_OFF
    __config _CONFIG2, _LVP_OFF & _LPBOR_OFF
    OSCCON = %01101000 ' set 4MHz internal osc
    CM1CON0.7 = 0 ; Disable comparator 1
    CM2CON0.7 = 0 ; Disable comparator 2
    ADCON0 = 0 'all ports set as digital
    ADCON1 = 0
    TRISA = %00100000 'PORTA.5 as input
    ANSELA = %00000000
    PORTA = 0
    TRISC = %00000100 'PORTC.3 as input
    LATC = 0
    PORTC = 0
    ANSELC = 0
    '******************** DEFINE VARIABLES ***********************
    temp_bit VAR BIT
    temp VAR BYTE
    spi_cnt var byte ' counter for SPI transfer
    bSPI var byte ' the byte being transferred on SPI
    s_addr VAR WORD ' Start Address
    e_addr VAR WORD ' End Address
    ISD_Data var byte[7] ' This array contains data to/from ISD
    SR0a var ISD_Data[0]
    SR0b var ISD_Data[1]
    SR1 var ISD_Data[2] ' only valid after ReadStatus
    isCmdErr var SR0a.0 ' 1=previous command failed/ignored
    isFull var SR0a.1 ' 1=memory full
    isPU var SR0a.2 ' 1=ISD powered up
    isEOM VAR SR0a.3 ' 1=EOM detected (clear by CLR_INT command)
    isINT var SR0a.4 ' 1=current operation completed (clear by CLR_INT command)
    isReady var SR1.0 ' 1=Ready to receive SPI command (only valid after ReadStatus)
    ' Some SPI commands can still be sent when isReady=0
    '******************** PIN ASSIGNMENTS ************************
    Symbol LED = PORTA.0 '
    Symbol miso = PORTC.2 'ISD1730 SPI MISO
    Symbol ss = PORTC.3 'ISD1730 SLAVE SELECT
    Symbol sclk = PORTC.1 'ISD1730 SPI CLOCK
    Symbol mosi = PORTC.0 'ISD1730 SPI MOSI
    '******************** INITIALIZATION *************************
    initialize:
    HIGH ss 'start with Slave Select HIGH
    HIGH sclk 'start with SPI Clock HIGH
    LOW MOSI 'start with MOSI LOW
    LOW led
    start: 'Initialize the ISD
    GoSub isd_pu
    PAUSE 50 '50 mS Power Up Delay (per datasheet)
    GoSub isd_clr_int 'clear interrupt and EOM
    '********************* MAIN PROGRAM **************************
    main_loop: '(MAIN PROGRAM LOOP)
    Playloop:
    if porta.5 = 1 then play
    goto playloop
    Play:
    high led ' LED for play
    if porta.5 = 1 then play 'wont play until button is released
    s_addr = $010 'playing back from the same 16 rows
    e_addr = $01f
    GOSUB isd_set_play
    PAUSE 2000
    GOSUB isd_stop
    low led
    goto main_loop
    '********************** SUBROUTINES **************************
    isd_pu:
    LOW ss
    bSPI=$01 'Power Up Command
    GoSub isd_spi
    ISD_Data[0] = bSPI 'SR0a
    bSPI=$00
    GoSub isd_spi
    ISD_Data[1] = bSPI 'SR0b
    HIGH ss
    isd_wait_ready:
    GOSUB isd_rd_status
    IF isReady = 0 THEN isd_wait_ready
    isd_set_play:
    LOW ss
    bSPI = $80 'Set Play Command (7 bytes)
    GoSub isd_spi
    bSPI = $00
    GoSub isd_spi
    bSPI = s_addr.LowByte ' Start Address low byte.
    GoSub isd_spi
    ISD_Data[2] = bSPI 'SR0a
    bSPI = s_addr.HighByte ' Start Address high byte
    GoSub isd_spi
    ISD_Data[3] = bSPI 'SR0b
    bSPI = e_addr.LowByte ' End Address low byte
    GoSub isd_spi
    ISD_Data[4] = bSPI 'SR0a
    bSPI = e_addr.HighByte ' End Address high byte
    GoSub isd_spi
    ISD_Data[5] = bSPI 'SR0b
    bSPI = $00 ' Reserved Address - set to "0"
    GoSub isd_spi
    ISD_Data[6] = bSPI 'SR0a
    HIGH ss
    isd_spi: ' shift SPI data out and into SPI byte
    FOR spi_cnt = 0 to 7 '
    MOSI = bSPI.0 ' shift LSB of byte onto MOSI line
    LOW SCLK ' clock MISO data out to uC (Falling Edge)
    temp_bit = miso '
    HIGH SCLK ' clock MOSI into ISD1700 (Rising Edge)
    bSPI = bSPI >> 1 ' shift SPI byte Right
    bSPI.7 = temp_bit
    NEXT spi_cnt
    isd_clr_int: ' CLEAR INTERRUPT AND EOM BITS
    LOW SS
    bSPI=$04 'Clear Interrupt Command
    gosub isd_spi
    bSPI=$00
    gosub isd_spi
    HIGH SS
    isd_stop: ' Stop Immediately
    LOW ss
    bSPI=$02 'Stop Command
    gosub isd_spi
    bSPI=$00
    gosub isd_spi
    HIGH ss
    isd_rd_status: 'read status of ISD1700
    LOW ss '
    bSPI=$05 'Read Status Command
    gosub isd_spi
    bSPI=$00
    gosub isd_spi
    bSPI=$00
    gosub isd_spi
    ISD_Data[2] = bSPI 'SR1
    HIGH ss
  1. ISD1700 series Winbond chipcorder
    By rickeybell in forum mel PIC BASIC Pro
    Last Post: - 21st March 2010, 07:13
  2. optical voice link
    Last Post: - 18th May 2008, 22:11
  3. Voice CODEC
    By Ron Marcus in forum Off Topic
    Last Post: - 15th May 2005, 20:28
