Winbond ISD1700 Voice Recorder
Results 1 to 40 of 59
    so someone would have to make himself friend with Winbond and suggest them an universal Gang device programmer
    Not sure this worth it, look at current storage device pricing and add a higher level Microcontroller to it... NO way you're going to be over the Price of any single Winbond IC... not to mention you can update any part of your firmware and sound using a simple bootloading process.
    Roman Black sounds almost the same as most Winbond solution and it's free, MP3 codec ICs are cheap, DsPIC are also cheaper... food for thought.
    Requires porting of basic code but take a look at PIC iPod wav player.
    Mono CD quality (16bit 44k) for the price of an SD card and holder,
    a PIC18F4520, a few resistors for an R2 ladder, an audio amp and a speaker.
    Or stereo 8bit 44k if preferred.
    Up to 2 Gig's or 512 wav files.
    Norm
    Sep 2005
    Dayton, Ohio
    Yes, Winbond (Nuvoton?) does/did offer a production gang programmer. 12 chips at once I believe. But cost is around $2000
    Jim Robertson
    "MilesTag" DIY Lasertag
    www.lasertagparts.com/mtdesign.htm
    Dayton, Ohio
    Jun 2007
    Jerson done a FANTASTIC job while not having any hardware to test with!! These ISD chips are difficult to work with at a glance anyways...
    I done more changing to the code I'm using by adding the 3rd byte to the status register and "singling out" the 2nd bit to check the status of the PLAY mode. With this bit, I can control the amplifier, which sound to play and when and so on...
    More than adequate for the application I have
    Sep 2005
    Dayton, Ohio
    This works so far to play back 4 sounds repeatedly. The volume setting via apc2 works also. Next I plan to get rid of the PAUSE delays and monitor status to determine when each sound finished playing.
    'DEMO PLAYER FOR ISD1700
    'Code Version: 01
    'Words Used = 354
    'Revision Date: 8 Feb 2009
    'PicBasic Pro Compiler version 2.50b
    'Processor=PIC16F684  (WDT=ON, MCLR=INPUT, OSC=INTOSC)
    'Modified from code posted by Jerson and Brenon
    'Memory Reference:
    'ISD17XX First Address = 0x010
    'ISD1730 Max Address   = 0x0FF
    'ISD1760 Max Address   = 0x1EF
    'ISD1790 Max Address   = 0x2DF
    	DEFINE OSC 8
    '******************** DEFINE VARIABLES ***********************
    temp_bit    VAR BIT
    temp		VAR BYTE
    spi_cnt 	             var byte	' counter for SPI transfer
    bSPI 		var byte 	' the byte being transferred on SPI
    s_addr		VAR WORD	' Start Address
    e_addr		VAR WORD	' End Address
    ISD_Data 	var byte[7]	' This array contains data to/from ISD
    SR0a 		var ISD_Data[0]
    SR0b 		var ISD_Data[1]
    SR1 		var ISD_Data[2]    ' only valid after ReadStatus
    isCmdErr 	var SR0a.0	             ' 1=previous command failed/ignored
    isFull 		var SR0a.1	' 1=memory full
    isPU		var SR0a.2	' 1=ISD powered up
    isEOM		VAR SR0a.3	' 1=EOM detected (clear by CLR_INT command)
    isINT 		var SR0a.4	' 1=current operation completed (clear by CLR_INT command)
    isReady 	var SR1.0	' 1=Ready to receive SPI command (only valid after ReadStatus)
    				        ' Some SPI commands can still be sent when isReady=0
    '******************** PIN ASSIGNMENTS ************************
    Symbol sensor	= PORTA.0			'
    Symbol miso		= PORTA.3			'ISD1760 SPI MISO
    Symbol led1	    = PORTC.1			'
    Symbol led2	    = PORTC.2			'
    Symbol ss		= PORTC.3			'ISD1760 SLAVE SELECT
    Symbol sclk		= PORTC.4			'ISD1760 SPI CLOCK
    Symbol mosi 	= PORTC.5         	'ISD1760 SPI MOSI
    '******************** INITIALIZATION *************************
    initialize:
        CLEAR
    	OSCCON = %01111000
    	CMCON0 = 7				'turn off comparators
    	ANSEL = 0
    	PR2 = 35				'PWM Period (40K=49, 56K=35) (35 to 55)
    	CCPR1L = 15				'PWM Duty Cycle (1 to 15)
    	T2CON = 4				'Timer2 = ON; Prescale = 1:1
    	CCP1CON = 0				'PWM module off
    	OPTION_REG = %11111111	'Turn off PortA weak pull-ups
    	TRISA = %111111    		'set PortA directions
    	WPUA =  %000000			'enable weak pull-ups PortA
    	IOCA =  %000000			'disable PORTA.0 Int On Change
    	TRISC = %000000    		'set PortC directions
    	PORTA = %000000
    	PORTC = %000000    		'
    	HIGH ss			'start with Slave Select HIGH
    	HIGH sclk		'start with SPI Clock HIGH
    	LOW MOSI		'start with MOSI LOW
        INPUT sensor
    	LOW led1
    	LOW led2
    start:                       'Initialize the ISD
    	GoSub isd_pu
    	PAUSE 50		         '50 mS Power Up Delay (per datasheet)
    	GoSub isd_wr_apc 	     'set volume and config bits
    	PAUSE 10
    	GoSub isd_clr_int	     'clear interrupt and EOM
    '********************* MAIN PROGRAM **************************
    main_loop:	'(MAIN PROGRAM LOOP)
        PAUSE 2000
        s_addr = $010
        e_addr = $02b
        GOSUB isd_set_play
        PAUSE 2500
        GOSUB isd_stop
        PAUSE 2000
        s_addr = $02c
        e_addr = $048
        GOSUB isd_set_play
        PAUSE 2500
        GOSUB isd_stop
        PAUSE 2000
        s_addr = $049
        e_addr = $07c
        GOSUB isd_set_play
        PAUSE 4800
        GOSUB isd_stop
        PAUSE 2000
        s_addr = $07d
        e_addr = $093
        GOSUB isd_set_play
        PAUSE 2000
        GOSUB isd_stop
    	GoTo 	main_loop
    '********************** SUBROUTINES **************************
    isd_pu:
    	LOW ss
    	bSPI=$01		'Power Up Command
    	GoSub isd_spi
    	ISD_Data[0] = bSPI 	'SR0a
    	bSPI=$00
    	GoSub isd_spi
    	ISD_Data[1] = bSPI 	'SR0b
    	HIGH ss
    isd_wait_ready:
    	GOSUB isd_rd_status
    	IF isReady = 0 THEN isd_wait_ready
    isd_set_play:
    	LOW ss
    	bSPI = $80		'Set Play Command (7 bytes)
    	GoSub isd_spi
    	bSPI = $00
    	GoSub isd_spi
    	bSPI = s_addr.LowByte 	' Start Address low byte.
    	GoSub isd_spi
    	ISD_Data[2] = bSPI	'SR0a
    	bSPI = s_addr.HighByte 	' Start Address high byte
    	GoSub isd_spi
    	ISD_Data[3] = bSPI 	'SR0b
    	bSPI = e_addr.LowByte 	' End Address low byte
    	GoSub isd_spi
    	ISD_Data[4] = bSPI 	'SR0a
    	bSPI = e_addr.HighByte 	' End Address high byte
    	GoSub isd_spi
    	ISD_Data[5] = bSPI 	'SR0b
    	bSPI = $00		' Reserved Address - set to "0"
    	GoSub isd_spi
    	ISD_Data[6] = bSPI 	'SR0a
    	HIGH ss
    isd_wr_apc:			'Write to APC Register using bits D2:D0 to set Volume
    	LOW ss
    	bSPI = $65		'Write APC2
    	GoSub isd_spi
    	bSPI = %01000011	'Volume set by D2:D0 (000=Max)
    				'Output set by D7 (0=Aud, 1=Aux)
    	GoSub isd_spi
    	bSPI = %00000100 	'PWM Speaker Output D8 (0=Enable, 1=Disable)
    	GoSub isd_spi
    	HIGH ss
    isd_spi:				        ' shift SPI data out and into SPI byte
    	FOR spi_cnt = 0 to 7        '
    		MOSI = bSPI.0 		    ' shift LSB of byte onto MOSI line
    		LOW SCLK 		        ' clock MISO data out to uC (Falling Edge)
    		temp_bit = miso         '
    		HIGH SCLK		        ' clock MOSI into ISD1700 (Rising Edge)
    		bSPI = bSPI >> 1 		' shift SPI byte Right
    		bSPI.7 = temp_bit
    	NEXT spi_cnt
    isd_clr_int:					' CLEAR INTERRUPT AND EOM BITS
    	LOW SS
    	bSPI=$04		'Clear Interrupt Command
    	gosub isd_spi
    	bSPI=$00
    	gosub isd_spi
    	HIGH SS
    isd_stop:					' Stop Immediately
    	LOW ss
    	bSPI=$02		'Stop Command
    	gosub isd_spi
    	bSPI=$00
    	gosub isd_spi
    	HIGH ss
    isd_pd:					' Stop Immediately
    	LOW ss
    	bSPI=$07		'Power Down Command
    	gosub isd_spi
    	bSPI=$00
    	gosub isd_spi
    	HIGH ss
    isd_rd_status:				'read status of ISD1700
    	LOW ss
    	bSPI=$05		'Read Status Command
    	gosub isd_spi
    	bSPI=$00
    	gosub isd_spi
    	bSPI=$00
    	gosub isd_spi
    	ISD_Data[2] = bSPI	'SR1
    	HIGH ss
    Jim Robertson
    Dayton, Ohio
    Sep 2005
    Dayton, Ohio
    I did some further testing. Seems the best way to determine when a sound has finished playing is to monitor the INT status bit. Just remember to clear the INT before each SET_PLAY.
    The PLAY bit will not work as it does not get cleared until you change to another mode (i.e. RECORD).
    The READY bit will not tell when the sound is completed playing, rather it tells you that the chip is ready to receive another SPI command (which can happen before the sound is complete when using SETPLAY).
    I couldn't find how to edit the previous post, so here are the changed parts:
    (obviously your start/end addresses will be different)
    mainloop:
        PAUSE 1000
        s_addr = $049
        e_addr = $07c
        GOSUB isd_set_play
        GOSUB isd_wait_int
        GoSub isd_clr_int
        PAUSE 1000
        s_addr = $07d
        e_addr = $093
        GOSUB isd_set_play
        GOSUB isd_wait_int
        GoSub isd_clr_int
        GoTo 	main_loop
    isd_wait_int:
    	GOSUB isd_rd_status
    	IF isINT = 0 THEN isd_wait_int
    Jim Robertson
    Dayton, Ohio
    Jun 2007
    Quote Originally Posted by milestag View Post
    I did some further testing. Seems the best way to determine when a sound has finished playing is to monitor the INT status bit. Just remember to clear the INT before each SET_PLAY...
    So monitoring the Int bit - reads 0 when the file is playing and sets to 1 when completed... I have completed the program for this chip in my application! : INSERT BOUNCY HERE:
    I'd REALLY like to thank Jerson for the initial beginning of this coding and to thank Jim for the clarifications needed to succeedingly write the final piece to operate my products.
    Brenon
    Last edited by ivirscar; - 8th February 2009 at 21:53. Reason: Clarification of post...
    Jan 2014
    Default Re: Winbond ISD1700 Voice Recorder
    I tried to play a recorded sound on ISD1730 but something is wrong. I use 16F1503 set at 4 MHZ. Can somebody help me..? Thx in advance
    CODE:
    __config _CONFIG1, _FOSC_INTOSC & _MCLRE_OFF & _CP_ON & _CLKOUTEN_OFF
    __config _CONFIG2, _LVP_OFF & _LPBOR_OFF
    OSCCON = %01101000 ' set 4MHz internal osc
    CM1CON0.7 = 0 ; Disable comparator 1
    CM2CON0.7 = 0 ; Disable comparator 2
    ADCON0 = 0 'all ports set as digital
    ADCON1 = 0
    TRISA = %00100000 'PORTA.5 as input
    ANSELA = %00000000
    PORTA = 0
    TRISC = %00000100 'PORTC.3 as input
    LATC = 0
    PORTC = 0
    ANSELC = 0
    temp_bit VAR BIT
    temp VAR BYTE
    Symbol LED = PORTA.0 '
    Symbol miso = PORTC.2 'ISD1730 SPI MISO
    Symbol ss = PORTC.3 'ISD1730 SLAVE SELECT
    Symbol sclk = PORTC.1 'ISD1730 SPI CLOCK
    Symbol mosi = PORTC.0 'ISD1730 SPI MOSI
    initialize:
    LOW led
    GoSub isd_pu
    Playloop:
    if porta.5 = 1 then play
    goto playloop
    Play:
    high led ' LED for play
    if porta.5 = 1 then play 'wont play until button is released
    s_addr = $010 'playing back from the same 16 rows
    e_addr = $01f
    GOSUB isd_set_play
    PAUSE 2000
    GOSUB isd_stop
    low led
    goto main_loop
    isd_pu:
    LOW ss
    GoSub isd_spi
    bSPI=$00
    GoSub isd_spi
    HIGH ss
    isd_wait_ready:
    GOSUB isd_rd_status
    isd_set_play:
    LOW ss
    GoSub isd_spi
    bSPI = $00
    GoSub isd_spi
    GoSub isd_spi
    GoSub isd_spi
    GoSub isd_spi
    GoSub isd_spi
    GoSub isd_spi
    HIGH ss
    temp_bit = miso '
    bSPI.7 = temp_bit
    NEXT spi_cnt
    LOW SS
    gosub isd_spi
    bSPI=$00
    gosub isd_spi
    HIGH SS
    LOW ss
    gosub isd_spi
    bSPI=$00
    gosub isd_spi
    HIGH ss
    LOW ss '
    gosub isd_spi
    bSPI=$00
    gosub isd_spi
    bSPI=$00
    gosub isd_spi
    HIGH ss
    derbende's Avatar
    derbende Guest
    thank you very much for the nice code.
    I have tested your code and it is working proerly. I can play and erase the voices by using ISD_ERASE and ISD_PLAY function. However I couldn't record any voices. I am very glad if you can help me. I can nor record any voices in defined addresses. how can I do it?
    'Code Version: 01
    'Words Used = 354
    'Memory Reference:
    	DEFINE OSC 8
    temp_bit    VAR BIT
    temp		VAR BYTE
    initialize:
        CLEAR
    	OSCCON = %01111000
    	ANSEL = 0
    	PORTA = %000000
    	PORTC = %000000    		'
        INPUT sensor
    	LOW led1
    	LOW led2
    	GoSub isd_pu
    	PAUSE 10
        PAUSE 2000
        s_addr = $010
        e_addr = $02b
        GOSUB isd_set_play
        PAUSE 2500
        GOSUB isd_stop
        PAUSE 2000
        s_addr = $02c
        e_addr = $048
        GOSUB isd_set_play
        PAUSE 2500
        GOSUB isd_stop
        PAUSE 2000
        s_addr = $049
        e_addr = $07c
        GOSUB isd_set_play
        PAUSE 4800
        GOSUB isd_stop
        PAUSE 2000
        s_addr = $07d
        e_addr = $093
        GOSUB isd_set_play
        PAUSE 2000
        GOSUB isd_stop
    	GoTo 	main_loop
    isd_pu:
    	LOW ss
    	GoSub isd_spi
    	bSPI=$00
    	GoSub isd_spi
    	HIGH ss
    isd_wait_ready:
    	GOSUB isd_rd_status
    isd_set_play:
    	LOW ss
    	GoSub isd_spi
    	bSPI = $00
    	GoSub isd_spi
    	GoSub isd_spi
    	GoSub isd_spi
    	GoSub isd_spi
    	GoSub isd_spi
    	GoSub isd_spi
    	HIGH ss
    	LOW ss
    	GoSub isd_spi
    	GoSub isd_spi
    	GoSub isd_spi
    	HIGH ss
    		temp_bit = miso         '
    		bSPI.7 = temp_bit
    	NEXT spi_cnt
    	LOW SS
    	gosub isd_spi
    	bSPI=$00
    	gosub isd_spi
    	HIGH SS
    	LOW ss
    	gosub isd_spi
    	bSPI=$00
    	gosub isd_spi
    	HIGH ss
    	LOW ss
    	gosub isd_spi
    	bSPI=$00
    	gosub isd_spi
    	HIGH ss
    	LOW ss
    	gosub isd_spi
    	bSPI=$00
    	gosub isd_spi
    	bSPI=$00
    	gosub isd_spi
    	HIGH ss
  1. ISD1700 series Winbond chipcorder
    By rickeybell in forum mel PIC BASIC Pro
    Last Post: - 21st March 2010, 07:13
  2. optical voice link
    Last Post: - 18th May 2008, 22:11
  3. Voice CODEC
    By Ron Marcus in forum Off Topic
    Last Post: - 15th May 2005, 20:28
