5v From Serial Port
Results 1 to 4 of 4
    TONIGALEA's Avatar
    TONIGALEA Guest
    Default 5v From Serial Port
    Hi everyone
    Just wanted to know if its posisble to derive 5v from the PC serial port to drive the pic
    Toni
    Jan 2004
    Thessaloniki , GREECE
    Default 5v from serial to PIC
    Hi!
    A method that I have tried and works nice is the following:
    9PIN Serial
    pin6(DSR)+pin7(RTS)+pin8(CTS) wired together goes
    through a diode 1n4148 to the input of a 78L05 . The ouput
    of the 78L05 goes to pin14 (Vdd) of the pic and Here it is!
    Don;t forget the ground pin5
    (DSR)+(RTS)+(CTS)-----------|>-|------IN GND OUT ------(to Vdd pic)
    ........................................1N4148.... ......78L05....................PIC
    Note: use only 78L05 regulator and you can also
    put an electrolytic capacitor 10uf/16v to the input of 78L05 to the ground.
    Attention: You can not draw to much mah from the serial port
    but it is ok to supply a single pic and low currnet peripherals.
    ALWAYS Use an extra serial card in you PC in order not to blow up
    your on-board stuff!
    TONIGALEA's Avatar
    TONIGALEA Guest
    thank you very much
    i only need to use it to power a max232 as i have tried in vain to reduce the current taken from my pic when in sleep mode
    but i still get about 3mA
    so i just thought that if i power the max232 from the pc it should
    draw current from the battery
    when i completely remove both the 5v and gnd from the max232
    my pic in sleep mode is 45uA which is good
    Toni
    TONIGALEA's Avatar
    TONIGALEA Guest
    Just a thought i am using a 9 way D-Type serial port
  1. serial port program in c
    By naveenupendran in forum Off Topic
    Last Post: - 28th February 2009, 11:47
  2. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 22:35
  3. Microcontroller with 2 way paging application problem
  4. serial port control relay
    By win_832001 in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2006, 23:56
  5. Replies: 2
    Last Post: - 28th April 2006, 12:10
