Lookup
Results 1 to 6 of 6
Thread: Lookup
    actionplus's Avatar
    actionplus Guest
    Default Lookup
    Anyone familiar with LookUp command?
    here is what my problem is. I have large data to look up. About 200 points of data.
    Here is a small portion of it.
    LookUp adval["55,55.2,55.4,55.6,55.8,56,56.2,56.4,56.6,56.8,57, 57.2,57.4
    ,57.6,57.8,58,58.2,58.4,58.6,58.8,59,59.2,59.4,59. 6,59.8,60,60.2,60.4,60.6,60.8,61,61.2,61.4,61.6,61 .8,62,62.2,62.4,62.6,62.8,63,63.2,63.4,63.6,63.8"],point
    Now the problem is that it compiles fine if I have only 1 line of data like this.
    LookUp adval,["55,55.2,55.4,55.6,55.8,56,56.2,56.4,56.6"],point
    How can I keep continuing to the next line and so forth like the first example from above?
    Santana's Avatar
    Santana Guest
    DO something Like This
    LookUp adval[55,55.2,55.4,55.6,55.8,56,56.2,56.4,56.6,56.8,57,5 7.2,57.4,_
    63.4,63.6,63.8],point
    actionplus's Avatar
    actionplus Guest
    Default error
    Still giving an error message.
    says it is expecting "]"
    actionplus's Avatar
    actionplus Guest
    Default Found the problem
    seem like the lookup table cannot contain any decimel points. Once I took of the decimals, it errors disappeared.
    Now, how can replace the decimal back into the lcdout command
    550 is suppose to be 55.0
    And
    2000 is 200.0
    never us any LOOKUP but
    LookUp adval,["55,55.2,55.4,55.6",_
    "55.8,56,56.2,56.4,56.6,56.8,57",_
    "57.2,57.4,57.6,57.8,58,58.2,58.4,58.6,58.8,59,59. 2",_
    "59.4,59.6,59.8,60,60.2,60.4,60.6,60.8,61,61.2,61. 4",_
    "61.6,61.8,62,62.2,62.4,62.6,62.8,63,63.2,63.4,63. 6,63.8"],point
    dont return any errors
    let me know
    Post
    Hi Actionplus,
    It seems like you discovered that PBP cannot handle decimal numbers.
    If you want to diplay your data with a decimal you could write ...
    LCDOUT "Data = ", DEC data/10, ".", DEC1 data
    .... or, if you want a little more control over each digit .....
    LCDOUT "Data = ", DEC1 data DIG 4, DEC1 data DIG 3, DEC1 data DIG 2, DEC1 data DIG 1, ".", DEC1 data DIG 0
    /Ingvar
  1. Graphic LCD with PICbasic pro
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 25th November 2012, 12:45
  2. Lookup Table
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 11:38
  3. ADCIN and LOOKUP ...
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 16th June 2007, 22:02
  4. problem with USART
    By leemin in forum Serial
    Last Post: - 11th December 2006, 18:56
  5. Confused On Dig & Lookup
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 5th December 2006, 22:49
