Multi-Threading
Results 1 to 23 of 23
Thread: Multi-Threading
    Setup a hardware peripheral like capture, hardware PWM, counter, UART, etc and enable
    it. They will all run simultaneously in the background while you're sampling the A/D input.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2008
    Hello. I am using the instant interrupt routine. I also posess a servo motor like ted,
    so I wand to start a pulsout every 20ms. I did this in the tmr0-interrupt routine(tmr0
    initialized by OPTION_REG = 1) I am using a 20Mhz quarz.
    I think: 20 / 4 = 5Mhz. OPTION_REG means prescaler = 1:1. Means 1/(5,000,000) equals 0.2us.
    TMR0 = 8Bit => 256 * 0.2us = 51.2us.
    So every 51.2us there will be an interrupt. So
    20,000 / 51.2 = 390.625 = 391. So as soon as the interrupt will have occurred 391 times 20ms
    should have been passed. I wrote
       '...do xyz
       counter = 0
      IRRoutine:
       IF counter = 391 THEN
        pulsout servo, duration
       IF counter > 391 THEN
        counter = 0
       IF counter < 391 THEN
        counter = counter + 1
       @ INT_RETURN
    But the servo is choppy. What is wrong?
    How does this work?
       '...do xyz
       counter = 0
      IRRoutine:
       IF counter => 391 THEN
        counter = 0
       @ INT_RETURN
    Sep 2008
    Well.
    But the servo is still choppy.
    I found the reason: Option_reg was wrong. I had a prescaler of 2:1.
  1. Multi Slow speed PWM and Instant Interrupts
    By DaveC3 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2010, 12:50
  2. multi functions button press
    By malwww in forum mel PIC BASIC Pro
    Last Post: - 27th May 2009, 00:12
  3. 16-48 pin Multi slow PWM
    By krohtech in forum mel PIC BASIC Pro
    Last Post: - 28th March 2009, 03:28
  4. Multi diomencinal array
    By morphyn in forum mel PIC BASIC Pro
    Last Post: - 11th February 2009, 21:19
  5. parallel port multi pic programmer?
    By SuB-ZeRo in forum Schematics
    Last Post: - 25th June 2005, 10:20
