Multi-Threading
Results 1 to 23 of 23
Thread: Multi-Threading
Threaded View
  1. #5
    Mar 2006
    China
    Default Read and understand
    If you look at the second post in this thread :
    http://www.picbasic.co.uk/forum/show...stant+interupt
    you will see a code snippet that ALMOST does what you want to do. It has a main loop where it is just performing a pause and then a timer is setup to toggle the led.
    This is very close to what you are asking for.. just enable the interupt before entering your task (so the led will start to flash) and when you exit your task disable it again.
    If you change the preloaded value (and prescaler if you have to) for the timer you can have different fast flashing led depending what task you are performing...
    This is not difficult because of the EXCELLENT code provided by DT.
    LED1   VAR  PORTB.1
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    my_task:
    T1CON = $31                ; Prescaler = 8, TMR1ON to desice how fast we will flash
    ;do all the stuff you want to do here
    @ INT_DISABLE  TMR1_INT     ; DISABLE Timer 1 interrupts
      GOSUB my_task
      PAUSE 10
    GOTO Main
    ToggleLED1:
         TOGGLE LED1
    @ INT_RETURN
    This might ( I didn't compile and test it, and I am not sure if it is the right register for your PIC) work and should flash the LED while you are performing my_task only.. just remember if my_task is very fast you might come out of it before we flash since the LED is flashing once per sec or something now.
    also we will go back to my_task every 10 sek... but what you do in your main loop I leave to you to decide.
    /me
  1. Multi Slow speed PWM and Instant Interrupts
    By DaveC3 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2010, 13:50
  2. multi functions button press
    By malwww in forum mel PIC BASIC Pro
    Last Post: - 27th May 2009, 01:12
  3. 16-48 pin Multi slow PWM
    By krohtech in forum mel PIC BASIC Pro
    Last Post: - 28th March 2009, 04:28
  4. Multi diomencinal array
    By morphyn in forum mel PIC BASIC Pro
    Last Post: - 11th February 2009, 22:19
  5. parallel port multi pic programmer?
    By SuB-ZeRo in forum Schematics
    Last Post: - 25th June 2005, 11:20
