help: countdown with timer0 interrupt
Results 1 to 13 of 13
    xnihilo's Avatar
    xnihilo Guest
    Well, it does not work as expected.
    First I have a problem with the other interrupts (I poster a message today about this) but with my settings I was expecting a TMR0 overflow evey 10ms but it happens every 1ms...
    TMR0 starts at 98, and I'm using a 8MHz intosc.
    0.5Us per instruction cycle (FOSC/4).
    Strange...
    Quote Originally Posted by xnihilo View Post
    Strange...
    8,000,000 Hz oscillator / 4 = 2,000,000 instructions/second = 2,000,000 increments of TMR0 using a prescale of 1:1 (prescaler assigned to WDT).
    TMR0 is an 8 bit timer, max count = 256. You're reloading it with 98, leaves you with 158 counts.
    2,000,000 / 158 = 12,658.228 Hz = 79us per interrupt.
    2,000,000 / 256 = 7812.5 Hz = 128us per interrupt.
    So, you're 10ms theory (since we don't have any better information) isn't going to work.
    But this might:
    http://www.mister-e.org/pages/picmulticalcpag.html
    xnihilo's Avatar
    xnihilo Guest
    8Mh/4 = 2000000 op per s.
    1:128 prescale = 2000000/128 = 15625 per s.
    Preload with 98, 158 counts.
    15628 / 158 = 98.89 Hz
    1000ms/100 = 10ms
    What's wrong?
    What's wrong?
    You left out that vital bit of information (the 1:128 prescale).
    So, it's happening every 1ms instead of 10ms?
    Are you sure you're correctly clearing/re-enabling the correct interrupt after you are done processing the interrupt...or is the interrupt sequence 'jumping right back into itself' after you are done processing it?
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Can't ID interrupt source with this IntHandler??
  3. Sleep Mode
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 11:31
  4. Ping Darrel Taylor - Timer0 Instant Interrupt
    By JEC in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 12:20
