help: countdown with timer0 interrupt
Results 1 to 13 of 13
    Quote Originally Posted by xnihilo View Post
    Define Osc 8
    I assume it means clock speed is 8000000 clock cycles per 1000000 microseconds, thus 125ns clock cycles.
    Right?
    If tmr0 is updated at every clock cycle it takes 256*125ns to set the tmr0 overflow flag in intcon register. If I use a 1:256 prescaler, it will take 256*256*125ns (=8.192 ms) before tmr0 overflows.
    Is that correct?
    Datasheet reference one more time...
    The PICs run at F(osc) / 4 , 4 clock cycles per instruction cycle. Therefore, at 4Mhz, the PIC executes 1 million single cycle instructions per second. At 8Mhz, 2 million single cycle instructions per second, 500ns per instruction cycle, which is what the timers are incremented from.
    Tmr0 overflows every 256 instruction cycles, 7812.5 timers per second.
    5 minutes = 300 seconds = 2,343,750 total overflows to get 5 minutes.
    If Tmr0 is capable of 16 bit (as it is in some PICs), then 9155.2734375 overflows to get 5 minutes.
    While the PIC is sleeping Timer0 will be off since on-chip clocks are shut down. You could
    use Timer1, but you would need an extermal clock during sleep.
    If it will be awake during your 5 minute time period, you could use the compare module set
    to reset Timer1 on each match. Load CCPR1L and CCPR1H with 62,500, set a prescaler of
    1:16, and it will interrupt every 500mS + automatically reset Timer1 to 0.
    Then you can just increment a variable in your int handler until your delay period is reached.
    This is a lot easier than reloading a timer in an int handler - or fiddling with adjustments to
    reload values compensating for code overhead.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    xnihilo's Avatar
    xnihilo Guest
    Smile
    You pointed out something I just read this afternoon: timer0 is frozen, which is a problem as I use "@ SLEEP" !!
    Well, my idea is to use the folowing parameters:
    With a TMR0 preset to 176 and a prescaler of 256 it will interrupt every 10ms.
    When in my lasergame program player health points drop below 0, it sets a variable (BIT) called CRITICAL to 1 and enable TMR0 interrupts.
    The routine handling the TMR0 interrupt would increment a counter variable and then it would go back to my main loop and... uh... go to sleep, disabling the timer...
    But, if I write (preseting CRITICAL to 0):
    (program starts here)
    loop:
    if (countdown == 1) THEN
    PAUSEus 15 'shortest pause I can use with a 8MHz clock
    @ SLEEP
    Goto loop
    Then when my countdown in the INT handler reaches the desired value, I disable the INT for TMR0 and set CRITICAL to 0 so the main loop will behave as it should: have a sleep when the INT handler has been processed.
    My question is: when sleeping, the interrupt will be handled then MCU will go back to "goto loop" or will it continue the "@ sleep"?????
    xnihilo's Avatar
    xnihilo Guest
    8MHz & Fosc/4 = 2MHz = 0.5Us per instruction cycle.
    Id 1:256 prescaler, it will count 256 instruction cycle before incrementing TMR0.
    Skimask, you say:
    "Tmr0 overflows every 256 instruction cycles, 7812.5 timers per second".
    I don't get it.
    256*0.5ns = 128 ns per overflow if 1:1 prescaler.
    1000000000ns / 128 = 7812500 iterations per second
    Skimask, you say:
    I don't get it.
    At 8Mhz, there are 2,000,000 instructions cycles per second.
    Assuming a 1:1 prescaler, with an 8 bit counter, you'll get 7812.5 Tmr0 overflow interrupts per second.
    256 * .5US = 128 US per overflow!
    You're off by 1,000 !
    xnihilo's Avatar
    xnihilo Guest
    Smile
    Jeeze! You are right. Sorry, I should have more @ SLEEP myself
    It would return to goto loop. The sleep instruction has already been executed.
    -Bruce
    tech at rentron.com
    xnihilo's Avatar
    xnihilo Guest
    Smile
    FIne, then that's what I need, right.
    It would work...
    Thank you very much.
    xnihilo's Avatar
    xnihilo Guest
    Well, it does not work as expected.
    First I have a problem with the other interrupts (I poster a message today about this) but with my settings I was expecting a TMR0 overflow evey 10ms but it happens every 1ms...
    TMR0 starts at 98, and I'm using a 8MHz intosc.
    0.5Us per instruction cycle (FOSC/4).
    Strange...
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  3. Sleep Mode
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 10:31
  4. Ping Darrel Taylor - Timer0 Instant Interrupt
    By JEC in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 11:20
    Last Post: - 6th March 2005, 01:07
