help: countdown with timer0 interrupt
Results 1 to 13 of 13
    xnihilo's Avatar
    xnihilo Guest
    Smile help: countdown with timer0 interrupt
    Hello.
    I need to start a 5 minutes countdown on a pic16f690.
    I have the very simple main program:
    Loop
    @ sleep
    Goto loop
    Then I have an int handler for triggerings on porta pins. In fact there are ir receivers on each porta pin and an ir beam triggers an int and specific actions are taken.
    I would need to use timer0 overflow interrupt. What I read from the datasheet is that timer0 is a 8 bits timer that can be used as either a counter or a timer, with prescaler.
    If I am using:
    Define Osc 8
    I assume it means clock speed is 8000000 clock cycles per 1000000 microseconds, thus 125ns clock cycles.
    Right?
    If tmr0 is updated at every clock cycle it takes 256*125ns to set the tmr0 overflow flag in intcon register. If I use a 1:256 prescaler, it will take 256*256*125ns (=8.192 ms) before tmr0 overflows.
    Is that correct?
    I would need 36621 iterations of a counter variable to get 5 minutes countdown (300000/8.192).
    Right?
    If I add in my int handler a routine that will increment a word variable at every tmr0 overflow, I can still get porta change interrupts.
    Right?
    I could have used a loop but during the loop (inside the int handler) no interrupt would occur.
    What do you think?
    Thanks a lot.
    Quote Originally Posted by xnihilo View Post
    Define Osc 8
    Right?
    Is that correct?
    Datasheet reference one more time...
    The PICs run at F(osc) / 4 , 4 clock cycles per instruction cycle. Therefore, at 4Mhz, the PIC executes 1 million single cycle instructions per second. At 8Mhz, 2 million single cycle instructions per second, 500ns per instruction cycle, which is what the timers are incremented from.
    Tmr0 overflows every 256 instruction cycles, 7812.5 timers per second.
    5 minutes = 300 seconds = 2,343,750 total overflows to get 5 minutes.
    If Tmr0 is capable of 16 bit (as it is in some PICs), then 9155.2734375 overflows to get 5 minutes.
    While the PIC is sleeping Timer0 will be off since on-chip clocks are shut down. You could
    use Timer1, but you would need an extermal clock during sleep.
    If it will be awake during your 5 minute time period, you could use the compare module set
    to reset Timer1 on each match. Load CCPR1L and CCPR1H with 62,500, set a prescaler of
    1:16, and it will interrupt every 500mS + automatically reset Timer1 to 0.
    Then you can just increment a variable in your int handler until your delay period is reached.
    This is a lot easier than reloading a timer in an int handler - or fiddling with adjustments to
    reload values compensating for code overhead.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    xnihilo's Avatar
    xnihilo Guest
    Smile
    You pointed out something I just read this afternoon: timer0 is frozen, which is a problem as I use "@ SLEEP" !!
    Well, my idea is to use the folowing parameters:
    With a TMR0 preset to 176 and a prescaler of 256 it will interrupt every 10ms.
    When in my lasergame program player health points drop below 0, it sets a variable (BIT) called CRITICAL to 1 and enable TMR0 interrupts.
    The routine handling the TMR0 interrupt would increment a counter variable and then it would go back to my main loop and... uh... go to sleep, disabling the timer...
    But, if I write (preseting CRITICAL to 0):
    (program starts here)
    loop:
    if (countdown == 1) THEN
    PAUSEus 15 'shortest pause I can use with a 8MHz clock
    @ SLEEP
    Goto loop
    Then when my countdown in the INT handler reaches the desired value, I disable the INT for TMR0 and set CRITICAL to 0 so the main loop will behave as it should: have a sleep when the INT handler has been processed.
    My question is: when sleeping, the interrupt will be handled then MCU will go back to "goto loop" or will it continue the "@ sleep"?????
    xnihilo's Avatar
    xnihilo Guest
    8MHz & Fosc/4 = 2MHz = 0.5Us per instruction cycle.
    Id 1:256 prescaler, it will count 256 instruction cycle before incrementing TMR0.
    Skimask, you say:
    "Tmr0 overflows every 256 instruction cycles, 7812.5 timers per second".
    I don't get it.
    256*0.5ns = 128 ns per overflow if 1:1 prescaler.
    1000000000ns / 128 = 7812500 iterations per second
    Skimask, you say:
    I don't get it.
    At 8Mhz, there are 2,000,000 instructions cycles per second.
    Assuming a 1:1 prescaler, with an 8 bit counter, you'll get 7812.5 Tmr0 overflow interrupts per second.
    256 * .5US = 128 US per overflow!
    You're off by 1,000 !
    xnihilo's Avatar
    xnihilo Guest
    Smile
    Jeeze! You are right. Sorry, I should have more @ SLEEP myself
    It would return to goto loop. The sleep instruction has already been executed.
    -Bruce
    tech at rentron.com
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Can't ID interrupt source with this IntHandler??
  3. Sleep Mode
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 11:31
  4. Ping Darrel Taylor - Timer0 Instant Interrupt
    By JEC in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 12:20
