160 Baud aldl scantool
Results 1 to 29 of 29
    Aug 2008
    so u will help me to do that or ????
    Jun 2005
    Wisconsin
    Quote Originally Posted by ahmed_salah View Post
    I think skimask's point is the folks on this forum will help answer specific questions but can't do the work for you.
    If you want the work done for you some member are willing to do it but they will charge for their services.
    Aug 2008
    and how much that will cost
    I don't think you'll find anyone to convert that program.
    It's the absolute worst ASM program I've ever seen.
    Label_0045  MOVLW   0x20
    Label_0046  MOVWF   0x1C
                MOVF    0x18      , W
                ANDLW   0x0F
                ADDLW   0x30
                MOVWF   0x1B
                RETLW   0x00
    Label_0029  MOVF    0x1C      , W
                CALL    Label_0003
                MOVF    0x1D      , W
                CALL    Label_0003
                MOVF    0x1E      , W
                CALL    Label_0003
                MOVF    0x1F      , W
                CALL    Label_0003
                RETLW   0x00
    Label_0031  MOVLW   0x04
                GOTO    Label_0047
                MOVLW   0x03
    Label_0047  MOVWF   0x12
    Label_0048  BCF     STATUS    , C
                RRF     0x15      , f
                RRF     0x16      , f
    No comments, numbered labels, yuck!
    I doubt that it could be converted without extensive knowlege of the protocol.
    And if they already knew the protocol, it would be easier to just rewrite it from scratch.
    Aug 2008
    thanks for your trying there are another ones do not want to help at all ???
    And who are these people??? The 500,000 ones who have not answered your post???
    Besides that...
    From what I see, I don't see the O/P asking for HELP as defined as HELP as defined as 'helping somebody out', as in somebody has done something and is looking for somebody else to assist in completion of something.
    What I see is still 'Could somebody do this for me'...
    And here's my contribution
    Should compile in PBP just fine!
    Here is what you do.
    Forget about the assembly, most likely will not work for you.
    From the zip you provided.
    I have tested this only with 1227747 ECM but it should work also with other 160 baud units after you have verified / altered ALDL data stream decoding to match with your application.
    You can blink an LED and make a LCD work. Learn about serial communications and write you own code. Then you can say that PBP paid for its self.
    Seems like the trick is in finding the protocol.
    Last Post: - 8th March 2010, 21:58
  2. PIC 18f1220 EUSART Baud Rate Cache Problem
    By wklose99 in forum Off Topic
    Last Post: - 15th April 2008, 01:39
  3. Auto Baud Rate Detection
    By mytekcontrols in forum Serial
    Last Post: - 31st October 2005, 03:17
  4. PIC12F675, accuracy of baud rate with Internal Oscillator
    By Chris Mayhew in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 23:41
  5. Baud Rate and Timing Calculator
    By picnaut in forum General
    Last Post: - 23rd January 2004, 17:48
