R/c
Results 1 to 4 of 4
Thread: R/c
    yaang's Avatar
    yaang Guest
    Question R/c
    Hi; this is my first post I hope this is the right section for my question
    Ive managed to make a working servo control system, it works quite nicely but now i want to make it Radio controlled. Unfortunately i dont have any experience with R/C, can you recommend me some guides or books about this ?
    Edit: IM using pic basic pro and 18F4550
    First I will suggest that you get things communicating with wires first, then an R/C module will almost be a drop in. ( sounds like you have done so, just a disclaimer)
    The parts I like are found here
    http://www.rentron.com/remote_control/TXLC-XXX-LR.htm
    Code examples can be found here too.
    Basically all you do is send the command with one of the serial protocols. A little signal conditioning and your good to go.
    dhouston has good info on his site.
    http://www.davehouston.net/
    I will not recomend any books, just a waste of time the most of them.
    Read the above two sites and this forum and that is all you will need.
    Quote Originally Posted by yaang View Post
    Hello yaang,
    First off, Welcome to the forum. Here is a link to a Google page customized to search this forum, I got this from Darrel Taylor. I set this as my home page, only it is set to search the internet by default.
    http://www.google.com/custom?hl=en&c...picbasic.co.uk
    yaang,
    Start with Dave's advice, and you'll do fine.
    Joe,
    Cool! and ...
    If you use google's custom home page, you can add this "Gadget" to show the forums RSS feed. It's got a nasty delay, but still kinda nice.
    http://www.google.com/ig/adde?hl=en&...rce=imag&val=9
  1. PBP projects for R/C models
    By malc-c in forum Code Examples
    Last Post: - 21st October 2016, 13:56
  2. R/C Failsafe Information
    By DanPBP in forum Off Topic
    Last Post: - 12th March 2009, 05:51
  3. R/C receiver to PIC16F84
    By tech in forum mel PIC BASIC Pro
    Last Post: - 12th September 2008, 17:45
  4. R/C Servo pulse Monitor
    By Harddkyss in forum Code Examples
    Last Post: - 25th February 2007, 16:00
  5. How to Read r/c signal PCM
    By jetpr in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2005, 08:06
