18F2620 Comparator Problems
Results 1 to 5 of 5
    Default 18F2620 Comparator Problems
    I'm trying to set up comparator interrupts on an 18f2620, but I can't even get it to work without interrupts. As soon as the comparator is enabled via the CMCON register, the program seems to off into la-la land. Here is a streamlined code snippet that illustrates the setup:
    define LOADER_USED 1
    define OSC 8
    disable
    on interrupt goto Process_Interrupts
    'Configure the LCD display
    output PORTB
    'Set LCD Data Port
    Define LCD_DREG PORTB
    'Set starting data bit (0 or 4) if 4-bit bus
    Define LCD_DBIT 1
    'Set LCD register select port
    define LCD_RSREG PORTA
    'Set LCD register select bit
    define LCD_RSBIT 0
    'Set LCD enable port
    define LCD_EREG PORTA
    'Set LCD enable bit
    define LCD_EBIT 1
    'Set LCD bus size (4 or 8 bits)
    define LCD_BITS 4
    'Set LCD number of lines
    define LCD_Lines 2
    'Set LCD command delay time (us)
    define LCD_COMMANDUS 2000
    'Set LCD data delay time (us)
    define LCD_DATUS 50
    output porta.4
    output portb.5
    temp var word
    adcon1 = 0
    ADCON1 = $FF 'No A/D converter
    'Configure the comparators
    CMCON.0 = 0
    CMCON.1 = 0 '4 inputs, mux'd to 2 comparators
    CMCON.2 = 0
    lcdout $FE,$1,$2
    Pause 500
    LCDOUT $FE,$80, "Inited"
    LCDOUT
    pie1 = 0
    pir1=0
    enable
    MainLoop:
    lcdout $FE,$80, "Main Loop"
    Pause 1000
    goto MainLoop
    Process_Interrupts:
    Disable
    LCDOUT $FE,$C0,"Interrupt"
    Pause 1000
    Resume
    Enable
    LCD output is produced at 3 critical points to trace where the program has gotten to:
    1) Completion of comparator initialization
    2) Main Loop
    3) Any interrupt
    So long as the CMCON register is in the default state, the program gets past initialization and into the main loop, with no evidence of any interrupts. However if CMCON is set to any operational mode, the program never even makes it to the initialization printout. Again, no interrupt message, just a blank display.
    It appears that, when CMCON is configured, the program either crashes or is off doing something that I can't fathom. I bent out all the PIC pins related to the comparator, so I don't think it's a surrounding circuit issue.
    Ideas?
    Joe
    Hi Joe,
    You got a few sticky wickets going on here.
    Define LCD_DBIT 1
    Like the comment says, it has to be either 0 or 4. 1 will not work.
    define LCD_RSBIT 0
    RA0 is a comparator input, you can't also use it for the LCD.
    'Set LCD enable bit
    define LCD_EBIT 1
    Same here, RA1 is a comparator input.
    output porta.4
    output portb.5
    temp var word
    adcon1 = 0
    CMCON.0 = 0
    CMCON.2 = 0
    You've set the Comparator output pins to OUTPUT. But then select a comparator mode that doesn't use outputs.
    lcdout $FE,$1,$2
    This clears the LCD then prints Custom Character 2, which hasn't been defined.
    Process_Interrupts:
    Disable
    Pause 1000
    Resume
    Enable
    The Disable should be before the Process_Interrupts label.
    And, YOU MUST clear the comparator interrupt flag before resuming.
    Darrel,
    Thanks for the reply.
    After I spent the better part of a day trying to figure out what I was doing wrong in software, I finally realized just what you spotted about the LCD drive signals - double duh on my part! I was about to post that I found the problem, but you beat me to the punch.
    In my production code however, I had the comparator mux set up so the offending LCD drive signal was deselected (or so I thought), so I'm a bit puzzled about why it affected the comparator. Anyway, moving E and RS to another port fixed it.
    The code snippet that I posted was actually a piece of test code I wrote just for this post to illustrate that just turning on the comparator causes the problem. Obviously I rushed and didn't check some of the other things you spotted. In my actual production code, everything is as you suggest it should be, except the LCD "Dbit" specifier. It actually works with a "1" instead of a "4", so I suspect that anything other that a "0" will work similarly - I'll check.
    Thanks for being so thorough. Sometimes another set of eyeballs locks right in on a problem that might have eluded one for hours.
    Joe
    Quote Originally Posted by Joe Rocci View Post
    I looked thru the PBP library files, and you're correct.
    The way it uses LCD_DBIT is always the same ...
      if ((LCD_DBIT) == 0)
    So anything other than 0 will be treated like a 4.
    I had thought you were starting the Data bus on PORTB.1, which wouldn't have worked.
    My mistake.
    It may work with 1, and automatically default to bit 4, but I wouldn't rely on this for anything down the road. The correct arguments are 0 or 4. If they make some change to a library file down the road, and you have 1 VS 4, this may screw-the-pooch after an update.
    I would opt for the correct arguments as shown in the manual just to be safe. I have seen stuff like this change with compiler updates, and it can end up being a real headache to debug.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. In Circut Debug (ICD) buttons palet is disable for 18F2620
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 17th June 2010, 05:21
  2. 18F2620 tmr0 and interrupts
    By astouffer in forum mel PIC BASIC Pro
    Last Post: - 8th March 2009, 00:56
  3. X-10 and the proper XOUT statement for 18F2620
    By JohnP in forum mel PIC BASIC Pro
    Last Post: - 10th December 2007, 22:04
  4. 18F2620 compile problems in PBP
    By Joe Rocci in forum mel PIC BASIC Pro
    Last Post: - 13th August 2006, 10:11
  5. How can I find Code Loader 18F2620 files ?
    By muskut in forum General
    Last Post: - 14th October 2005, 12:26
