Receive serial data
Results 1 to 19 of 19
    Bruce, skimask,
    Thank you very much for your help.
    Will try when i get home, but it makes perfect sense !
    Another thing to try is just a plain DEC.
    DEBUGIN [DEC MyVar]
    DEC waits for a numeric character and discards anything else until it gets one. Once it receives a character that is a number, it continues receiving more digits until it gets a non-numeric char which would be the 13.
    This way the value can be any length, and you don't have to convert it to a byte.
    Thanks Darrel Taylor,
    will try your code too.
    [edit]never mind
    Hi all,
    just to let you know that it worked. I came across some issues but i managed to fix them.
    One of the issues was that i had to use a 10K pull down resistor between my logger and the new receiver.
    I kept a simple code and it works and no loss of data was found.
    here's the tryout code:
    'PINS
    n5 	var GPIO.5
    n4 	var GPIO.4
    BUT 	var GPIO.3
    led     var GPIO.2
    n1	var GPIO.1
    IN   	var GPIO.0
    DEFINE OSCCAL_1K 1
    define OSC 4
    @ DEVICE pic12F675, INTRC_OSC_NOCLKOUT
    @ DEVICE pic12F675, WDT_OFF
    @ DEVICE pic12F675, PWRT_OFF
    @ DEVICE pic12F675, MCLR_OFF
    @ DEVICE pic12F675, BOD_ON
    Include "modedefs.bas" ' Include serial modes
    DEFINE debug_reg gpio
    DEFINE debug_bit 1
    DEFINE debug_baud 9600
    DEFINE debug_mode 1
    DEFINE DEBUGIN_REG GPIO
    DEFINE DEBUGIN_BIT 0
    DEFINE DEBUGIN_MODE 1
    ADCON0=0
    ANSEL=0
    CMCON=7
    trisio=%00111001
    GPIO=0
    START:
    led=0
    if but=1 then
    goto rc
    goto start
    rc:
    led=1
    DEBUGIN [DEC VALUE]
    DEBUG dec VALUE,13,10
    goto rc
    Thanks for the help
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 02:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
