Receive serial data
Results 1 to 19 of 19
    Quote Originally Posted by ruijc View Post
    The recorded temperatures from the logger are between 0 and 160șC.
    1 degree granularity (i.e. 10C 11C) or less than that (i.e. 10.2C 11.547381223430947C)?
    Just 1 degree granularity 10, 11, etc
    Well, if it was me, and I wanted close to 100% assurance that my data was good, I guess I'd go a little bit crazy and do something like have a 'packet' of X number of bytes, each packet for one temperature reading for each 'location'...
    packet start ID (example of $FF)
    address X.lowbyte
    address X.highbyte
    data byte
    same data byte (inverted)
    address X.highbyte (inverted)
    address X.lowbyte (inverted)
    packet end ID ($00, which is the packet start ID inverted)
    So, I'd end up with an 8 byte packet, everything is sent, then it's all sent again but inverted at the bit level. The packet start ID might be an $FF (because the temp's will never be that high), the addresses might be that high, but if you got that then the packet end ID wouldn't match up.
    It's a bit overkill, but I don't see why it would work. And really, I think I'd trust my wiring enough to just send a couple of $FF's as a start marker, then the whole recorded memory from start to finish, maybe with a couple of $FF's as an end marker.
    It's all up to you. You get to make RSP... ruijc's serial protocol.
    Thanks Skimask,
    I agree. Me also.
    It makes perfect sense.
    The reason i'm with this system it's because it was simple to build and simple to transfer the data to the PC using a freeware RS232 logger software. I just dump the values to it with the format i have showned ( one temp value per line ) saving them in a txt file and then just import to excel and generate the graphs.
    The reason i'm asking how to do this with this system is that this way i can maintain my logger as is and just need to build the module with LCD to view the data "on site".
    I cannot re-program the logger because it's encapsulated with resin to reduce size and weight.
    If it could be done i was more than half way there to complete the module
    Default logging
    sorry, didn't read last post
    Any idea how to collect the data ? anyone ?
    I have not tried it, but could you use 10 or 13 for the wait character and then store the data.
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 01:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
