5x7 LED Matrix Scrolling Display
Results 1 to 19 of 19
    If these is a way to paste a picture here I would.
    Have a look at this thread. Talks about inline pictures. Or just do an attachment.
    http://www.picbasic.co.uk/forum/showthread.php?t=9156
    I have not been able to find the data sheet for the shift register you have.
    Basically there are three pins on the shifter that need controlled and one sometimes two can be paired up when using multiple shifters. (shifters being in or out).
    If I remember correctly, parralax has good documentation somewhere about how to make a shifter work with a stamp.
    If someone else does not get to it first, I will dig up a snippet when I get home and post it for you.
    Here is a little bit that may get you started. The PBP manual will help to explain some.
    'Pin setup
        include "modedefs.bas"
    ' The clock and load pins can be shared_
    'on all shifters
    'Data pins are for each shifter
        Clock   var PORTB.7
        Load    var PORTB.6
        Data_1  var PORTB.5
        Data_2  var PORTB.4
        LEDs_1  var byte
        LEDs_2  var byte
    'Send data to the shifter
        pulsout Load,1
        shiftout Data_1,Clock,MSBPre,[LEDs_1]
        pulsout Load,1
        shiftout Data_2,Clock,MSBPre,[LEDs_2]
    Now the fun part, if you have the data sheet for the shifter it will help.
    If it is a serial to parallel register, sending the value of 2 should make the first output pin on the shifter go high, a value of 4 activate the second pin, a value of 6 both pin 1 and 2. And so on. Each pin up is double from the last. To send to multiple pins, add the values for each pin. This is the same for shift in registers.
    This is interesting
    http://www.eelab.usyd.edu.au/digital...egister03.html
    'Pin setup
    'on all shifters
        Clock   var PORTB.7
        Load    var PORTB.6
        Data_1  var PORTB.5
        Data_2  var PORTB.4
        LEDs_1  var byte
        LEDs_2  var byte
        pulsout Load,1
        pulsout Load,1
    This is interesting
    Hi Roy, Hi Mackrackit,
    Have you unzipped Trent's 245 LED post, I have , he provides a nice VB program to send data to his display, all the code, a pdf article on building it, and the code is in PBP, a good read to be sure. http://www.picbasic.co.uk/forum/showthread.php?t=6033 BTW that 74HC425 is either very obscure or the number is either been <font color=red>misread</font color> or is someone's house numbered device, without seeing the schematic it is hard to guess what it really is.<br> Mackrackit, thanks for that last post, a good study.
    Hi Roy,
    I suspect that the 74HC425 might actually be a 74HC42<b>S</b> in which case it would be a BCD to decimal decoder - which sounds plausible. http://www.datasheetcatalog.com/data.../74HCT42.shtml
    here is a circuit that uses them to drive an 8x8 scrolling display
    http://www.antrak.org.tr/gazete/1220...image/sema.gif
    Here is the supporting text (I hope your Turkish is good )
    http://www.antrak.org.tr/gazete/122003/ali_yetis.htm
    Gülegüle
    Pat. Pending
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. 8x8 Scrolling LED display (Simple example)
    By wellyboot in forum Code Examples
    Last Post: - 11th July 2013, 05:03
  3. Replies: 2
    Last Post: - 14th July 2008, 22:11
  4. 245 Led Matrix Display (as constructed by Magu)
    By magu in forum Code Examples
    Last Post: - 29th June 2007, 00:07
  5. LCD will not start
