5x7 LED Matrix Scrolling Display
Results 1 to 19 of 19
Threaded View
  1. #5
    Quote Originally Posted by roycarlson View Post
    Sorry Guys,
    Please forgive me for stepping on your skills and asking for direction to some sample code to use as a backdrop to getting a 5x7 Matrix Display working.
    I know I should learn from scratch all over again as I spent last year working through several of Parallax's beginner courses to get the basics. I am neither a software or microchop professional - only a hobbyist looking to learn to build things and have fun.
    It is probably me that is in error - but your replys seemed to condem me for not starting with the basic lesson (which I did by buying two books and the PicKit2 along with the 44 Pin demo board.
    Moving over from Parallax Basic to PicBasicPro is very different in that a lot more pre conditioning has to take place for the software to work with the many different chips that are out there to use.
    I have also gone through lessons using PicAxe chips and was directed to PBasic & Pics by Reynold's Electronics as a means to save money - not true.
    All I wanted to know is if anyone has developed software to run 4 - 5x7 LED Matrix Displays and what 40 Pin PIC would work best to program. I stated that the board I purchased and built uses 2 74HC425 chips to control the rows and 20 3904 transistors to control the columns.
    The website listed for the part I built was working when posted.
    IN CLOSING - HOW DO I REMOVE MY POST OR EDIT?
    Hi Roy,
    I would ask that you reconsider, I do not believe anyone is condemming you, So many beginners come with wide eyes and plans for projects beyond their abilities and end up frustrated believing this is impossible, that's all. That said here is a link for starters:
    http://www.picbasic.co.uk/forum/showthread.php?t=3739, as I get time I will look for others.
    Oh and speaking of Bruce, here is a tidbit ON HIS WEBSITE : http://www.rentron.com/PicBasic/Movi...ge_Display.htm there appears to be more than 1 example here including links to one in C.
    http://www.picbasic.co.uk/forum/showthread.php?t=6033
    here is something using shift registers: http://www.instructables.com/id/LED-...ift-registers/
    using PIC:http://www.instructables.com/id/EI8L4C81FIEV2ZF7JP/
    <marquee scrolldelay="125" width="50%"> Nobody leaves here hungry, unless they want to. </marquee>
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. 8x8 Scrolling LED display (Simple example)
    By wellyboot in forum Code Examples
    Last Post: - 11th July 2013, 05:03
  3. Replies: 2
    Last Post: - 14th July 2008, 22:11
  4. 245 Led Matrix Display (as constructed by Magu)
    By magu in forum Code Examples
    Last Post: - 29th June 2007, 00:07
  5. LCD will not start
