Hi Darrel--
Right on about the channel, it should say 6. Otherwise, I don't think it's a hardware issue, i.e. resonator vs. crystal... I've been using PBP code (follows) to capture a single channel or two and it works great, but I'd like to get the whole 512 channels, hence trying to adapt AN1075. I think its getting lost somewhere... could this have something to do with BANK0, BANK1, etc?
This is the PBP routine that I have been using to read 2-3 channels at a time; on this same hardware platform it works great...
Code:'==================================================== ' DMX Subroutines '==================================================== readdmx: counter = 1 PIE1 = 0 ' Mask the interrupt pulsin target, 0, counter idleflag = 0 DMX_OK = 1 if counter = 0 then idleflag = 1 'either no DMX or break timed out DMX_OK = 0 'set DMX as not present goto noshow_exit endif if counter < 35 then readDMX 'active pulse too short, keep looking 'otherwise its valid DMX & time to read the start code dummy = rcreg dummy = rcreg 'do this twice to clear out ang garbage in the USART spbrg = 0 txsta.2 = 0 'brgh = 0 txsta.4 = 0 rcsta.7 = 1 'turn on the USART rcsta.6 = 0 'setting 8 bit receive mode, no parity, etc. rcsta.4 = 0 rcsta.4 = 1 'toggle the rcsta.4 bit to make-ready while rcif = 0 : wend 'hover until start code is received startcode = rcreg 'read the startcode somewhere, tho most likely we'll never look at it if dmx_channel = 1 then 'if DMX address is 1, do this special case dummy = rcreg goto exit_readDMX endif 'else, do this code for DMX addresses 2-512: count0 = 0 While count0 < (dmx_channel-1) 'set up loop to count up to just 1 shy of target address while rcif = 0 : wend 'wait for a byte dummy = rcreg count0 = count0 + 1 WEND exit_readDMX: DMX_data = rcreg 'put the DMX byte into a variable and exit noshow_exit: rcsta.7 = 0 'turn off the USART if intensity > 0 then PIE1 = 1 'restore interrupt else PIE1 = 0 'if the intensity is >0, let the elapsed timer run endif return
