Start bit
Results 1 to 5 of 5
Thread: Start bit
    Feb 2008
    Question Start bit
    Does anyone know how to add a start bit to either of the PIC Basic
    commands SEROUT and SEROUT2. The handbook indicates that the default
    settings are 8 data bit, no parity and one stop bit. Many thanks.
    skimask's Avatar
    skimask Guest
    Talking
    Quote Originally Posted by Tekky View Post
    There are no options for start bits in SEROUT and SEROUT2.
    You can't add one, therefore you can't start serial communications.
    skimask's Avatar
    skimask Guest
    Default Sorry :D
    Sorry, I couldn't resist... If I had the graphic for the guy laughing on the floor I'd post it, but I don't...
    Start bits are always present. Start bits are about the only thing that's constant in async-serial comm's. You can't have asynchronous serial communications without a start bit. Well, you could, but I can assure you it wouldn't work very well.
    http://en.wikipedia.org/wiki/Asynchr..._communication
    Feb 2008
    Default Start bit
    Many thanks for the info. Since posting I have looked at several serial comms
    sites and seen that the start bit is necessary for synchronisation. I have been confused
    by the PIC Basic literature not stipulating the fact the start bit must be present in the routine. Again many thanks.
    The start bit is already there. You don't need to ad it. Standard serial comms = 1 start bit
    followed by 8 data bits, followed by the stop bit, which is just an idle period where the TX
    pin is held at idle logic for one bit period before the next byte can be sent.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Last Post: - 14th June 2016, 08:55
  2. AT/PS2 Keybord - PIC Interface?
    By Kamikaze47 in forum Code Examples
    Last Post: - 9th August 2009, 17:10
  3. PICBasic newbie problem
    By ELCouz in forum mel PIC BASIC Pro
    Last Post: - 12th February 2008, 01:55
  4. Replies: 0
    Last Post: - 5th October 2005, 23:06
  5. USART interrupt not interrupting right
    By Morpheus in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 02:07
