Alternative to the H44780 lcd controler
Results 1 to 12 of 12
    Aug 2005
    Thanks for the reply skimask, but the problem is that I wouldn’t even know where to start. I’ve tried searching the forums for examples but the nearest I found was a custom serial out routine. I can get a display that uses HD66712 controller, which would be ideal for my project. But I cannot find any example code that would drive it. Or at least a good place to start.
    Thanks Sphere..
    Quote Originally Posted by Sphere View Post
    Thanks Sphere..
    I just googled and found a datasheet for the HD66712U controller, and while it's not a datasheet for an actual LCD, it's good enough for me.
    The datasheet says it's upwardly compatible with the HD44780, and like I said in your last bunch of posts about LCDs, from reading the '712 datasheet, it looks like it 'compatible enough' with PBP's LCDOUT commands to make it work just fine without doing anything out of the ordinary. And if it turns out that I missed something that's buried in the datasheet, the register set, the commands, the timings, all look like they're 44780 compatible, therefore PBP LCDIN/LCDOUT comapatible.
    Of course, this doesn't mean that your particular LCD module (probably with a master controller of some sort with probably a few slave controllers and maybe some other glue logic on board) follows the 'normal' way of doing things and it is actually completely PBP LCDOUT compatible. But I don't know what your 'chosen' LCD module is, so I can't comment on that. That's the problem with limiting yourself to a particular LCD module. If it doesn't work...Nothing works.
    If you're having problems with setting something up (as you seemed to be in your last thread about LCDs), then post the problems. Quite frankly, driving this type of LCD doesn't look like brain surgery, and should be a piece of cake to get running.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 11:43
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 14:44
