Help with simple program
Results 1 to 9 of 9
    Jul 2008
    I'm From Krooklyn
    Default Sorry, did not provide a lot of information.
    Thank you for such a fast reply.
    I'm sorry I did not include all the information required to make a proper assesment. So with this in mind here I go again:
    I'm using a PIC development board that provides all necessary connections. I.E. MCLR tied to +5 volts via a series resistor, 4 mhz crystal prewired with proper caps and LED's cathode tied to RC0 whilst the anode is connected to a series resistor tied to 5 volts. All voltages are prewired and supplied via a 12 volts transformer and stepped down with a 7805 voltage regulator. If I run a sample program that is supplied with the development board the PIC IC and the peripherals all work properly. My guess, as per your suggestion, is that my problem is in the "config fuses" portion of the program. So my next course of action would be to read up on this topic and see how to configure this requirement. However, if it is not too much trouble, could you point me in the right direction?
    Thank you for your time.
    <b>FAQ</b> is not a cryptic way of cussing someone out, Melaine herself wrote this one, now about 14 posts down: http://www.picbasic.co.uk/forum/showthread.php?t=543
  1. Simple Blink program doesnt work.
    By sccoupe in forum mel PIC BASIC Pro
    Last Post: - 1st March 2009, 21:30
  2. Making Program Code Space your playground...
  3. simple counting program - please help!!
    By john meiers in forum mel PIC BASIC
    Last Post: - 20th February 2006, 14:17
  4. Simple RS232 Program
    By BlackNoir in forum mel PIC BASIC Pro
    Last Post: - 8th January 2006, 01:57
  5. Simple Interrupt Program
    By eoasap in forum General
    Last Post: - 28th October 2005, 17:22
