Bit variables... typo?
Results 1 to 7 of 7
    Tomexx's Avatar
    Tomexx Guest
    Default Bit variables... typo?
    This snippet below is taken from MElabs website:
    http://www.melabs.com/resources/articles/pinaccess.htm
    Specifying bits with variables
    Sometimes it is desirable to specify the bit with a variable in your program. This allows you to write to different bits, based on some condition in your code.
    Let's write a code snippet which will count 0 to 7 and make the corresponding bit on PORTB high for each count. To do this, we will use a bit offset.
    i    var    byte    ' i will hold our count
    TRISB = %00000000    'set all PORTB pins as output
    For i = 0 To 7    'loop for 8 counts
        PORTB = %00000000    'make all pins low
        PORTB.0[i] = 1        'make pin number i high
        Pause 500            'pause for half a second
    Next i        'go to the next count
    Notice the PORTB.0[i] line is that a typo?
    If not why is the "[i]" located next to ".0"?
    Please explain how it works
    Tom
    one things is stupid frome MELABS, is not allowing to write...
    PORTA.i
    anyway, we can consider PORTB.0[i] as a kinda typo.
    Tomexx's Avatar
    Tomexx Guest
    Too bad...I was hoping to use it in an array.
    Anyway, so if we can't use an array here then what's the point of the example?
    Tom
    Depending of what you want to do with an array... what do you plan to do?
    Tomexx's Avatar
    Tomexx Guest
    Nothing particular in this case. Just that the example said that you can specify the bit with a variable in your program which I didn't see in the manual. I thought that would be usefull sometimes. But I didn't understand the syntax.
    PORTB.0[i] = 1
    Going back to the example they probably meant this:
    PORTB.[i] = 1
    ...so I guess you can use it in an array otherwise they wouldn't show it, right?
    Anyway, I'm pretty new to the PBP and try to pick up new things when I see them. Also PBP is very limited compared to PC languages so every little trick helps.
    Ok, i'm not sure what you know and what you don't so here's fulll explanation.
    PORTB.0=1
    high level state to PORTB bit 0 (RB0). This is doing the same thing as HIGH PORTB.0
    PORTB.0[i]=1
    high level state to PORTB bit specify by i variable
    So let's say i=4, this will place PORTB bit 4 (RB4) to high level.
    i don't see lots of appliance for this function since i always use specific name to access an PORT pin.
    hope this put some lights
    regards
    It's all here if you search for it...
    http://www.picbasic.co.uk/forum/show...=&threadid=544
    Last Post: - 14th June 2016, 07:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 10:38
  3. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
  4. How to tell which PICs can handle 16 bit variables?
    By MikeTamu in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 08:44
    Last Post: - 6th March 2005, 01:07
