Automatically incrementing version counter/variable
Results 1 to 5 of 5
    Default Automatically incrementing version counter/variable
    A variable readable at run time that automatically increments every time PBP is invoked (a BYTE for some, a LONG for a few of us).
    PBP might have an .ini file that would match the .pbp filename and keep various PBP parameters in there along with the version count.
    Then at run time, something like this happens:
    version_variable var WORD 'or BYTE or LONG or whatever
    version_variable = pbpversion
    lcdout "Current Version is : " , DEC5 version_variable
    If nothing else, it might be kinda fun to see how many times a guy compiles a certain program just to see how many times you program a particular PIC.
    Something like that could be done in MPLAB with custom build option or with Version control option.
    I've never used it, and still don't see any advantage if using it though.
    Save As, and edit the program header.
    http://www.astrosurf.com/soubie/serialisateur.htm does just that.
    Anand
    Wink some more files to download ...
    Hi, Anand
    Also, Do not forget to add :
    VCL50.BPL
    VCLX50.BPL
    in the utility Directory ...
    those can be found on the WEB ...
    Then just add INCLUDE " C\...\Serinfo.bas" to the top of the BASIC file :
        ' Serial for PBP (c) 2002 Robert Soubie
        ' Type source code or comment lines hereunder,
        ' Syntax should be valid since no control is done;
        ' This window may be empty, or source code may be
        ' pasted into it...
        ' Software version information:
        MajorVersion      CON 1
        MinorVersion      CON 0
        ' Compilation date information:
        CompilationYear   CON 2008
        CompilationMonth  CON 6
        CompilationDay    CON 15
        CompilationHour   CON 11
        CompilationMinute CON 4
        ' Serial number information:
        SerialNumber      CON 2
    Here it is ...
    Right, thanks, Alan.
    The version of PBP Serialisateur I had downloaded did contain a file VCLSMP50.BPL in the zip that seemed to achieve the same.
    Anand
  1. Version Control
    Last Post: - 16th October 2011, 17:12
  2. New version of Pic BASIC Pro released
    By Demon in forum mel PIC BASIC Pro
    Last Post: - 12th March 2010, 15:41
  3. version numbering
    By rondo2 in forum General
    Last Post: - 13th January 2010, 00:59
  4. current version of MPASM
    By krohtech in forum mel PIC BASIC Pro
    Last Post: - 30th January 2008, 22:11
  5. DT-ints-18 - new version
    By dip1 in forum mel PIC BASIC Pro
    Last Post: - 10th October 2007, 20:09
