A2D issues on PIC16F876A
Results 1 to 8 of 8
    Darrels' note on using the correct arguments with ADCIN should cure it. Using the port bit
    reference doesn't set it to the correct channel, so that's the major issue.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2007
    Houston, TX
    DT & Bruce,
    You were right about the channel numbers, Don't know were I got the idea to use "porta.?" instead of the # itself. Anyway all is well now. thanks again!
    Padawan-78
  1. Solved: notes on annoying little issues
    By Probotics in forum mel PIC BASIC Pro
    Last Post: - 26th May 2008, 21:02
  2. Circuit reliability issues
    By hkpatrice in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2007, 15:55
  3. Migrating PIC16F876a to PIC18F252
    By cohenjdc in forum mel PIC BASIC Pro
    Last Post: - 1st June 2007, 14:55
  4. Runing a PIc16F876A
    Last Post: - 7th January 2007, 13:54
  5. how to get PCF8574 and PIC16F876A work together
    By nomada in forum mel PIC BASIC Pro
    Last Post: - 15th December 2004, 03:07
