Power problems
Results 1 to 40 of 51
Thread: Power problems
    Jun 2008
    Well, I really dont know what do more.
    On the test board everything was ok. The LED was blinking, the LCD shows the numbers.
    Now I wrap it again and it aint work, unless I touch the 8Mhz crystal with my hand ;-0
    Jun 2008
    And ofcourse, if using the programmer power , everything is ok (with MCLR stright to the +5v)
    Quote Originally Posted by menta View Post
    That usually indicates a missing ground and/or pullup or pulldown somewhere, likely on MCLR, or missing cap's between Vdd and Vss (both pairs and across the pairs).
    USA - Arizona
    Look at the grounds. Make sure they are very nice, short, and fat traces (or wires). The traces (or wires) from the crystal to the PIC should be as short as possible. The capacitors on the crystal should also be as close as possible to the PIC, with direct connection to GND. Pay good attention to the MCLR connection (follow the datasheet, they did not went through all that trouble for no reason).
    This is what I tried to explain before. The 877A has external MCLR and external oscillator (the 887 has the capability to run both of them internally - not good comparison).
    Jun 2008
    How do you explain that when using the power from the programmer, everything is OK ?
    The programmer may hold MCLR low while Vdd comes up and release MCLR after a few milliseconds. Put a 'scope on it and see if you can see anything.
    Jun 2008
    I'm not using all programmer legs, just + and -
    Just for giggles.
    If you do not have a scope or frequency meter. Use you DVM set for AC and se what the the voltage is from the programmer vs the out put of the 7805.
    If you can measure frequency the take that measurement.
    Jun 2008
    Its amazing,
    When I use the test board (http://dj-gil.com/PIC/posts/math.jpg) everything is ok.
    When I put in the wireWrap board (http://dj-gil.com/PIC/posts/WW1.jpg)
    (http://dj-gil.com/PIC/posts/WW2.jpg) its not working.
  1. Battery powered applications
    Last Post: - 22nd June 2009, 07:12
  2. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 10:34
  3. HSerin problems on power up
    By Luckyborg in forum Serial
    Last Post: - 21st April 2009, 19:49
  4. 12 Servo's together does not seem to work, Power problem
    By macx75 in forum mel PIC BASIC Pro
    Last Post: - 13th December 2006, 19:30
  5. problems on power up of PIC
    By dmairspotter in forum mel PIC BASIC Pro
    Last Post: - 13th June 2006, 14:11
