Project working .. Nuke is happy now
Had the right code for setting HAEN but I was sending it to the wrong address.
Thank you very much This helps me alot
Only one thread on the 23S08. Well, maybe someone can help.
I believe my problem is in the hardware but if someone can check the command below, that would be great. I took the attached file in the first thread and believe only the write command needed to be changed. I modified it to this but I still get nothing out of the 23S08. I'm using the PICkit serial SPI board.
MCP_WRITE:
low CS
SSPBUF=0
GOSUB CLOCK_BIT
SSPBUF = spout
high CS
I feel like something is missing in there. Also, to rule out the board, I was toggling one pin at a time. When I toggle the MOSI or MISO pins, the both appear to be connected because both pins go high and low at the same time. In other words, I pulse the MOSI with a 2 Hz signal and the MISO pin appears to be in parallel.
Confused....
After loading SSPBUF the second time, you need to wait for it to finish the transfer before taking CS high again.
No dice. I think that command was wrong and this one *looks* correct after doing some more reading.Maybe one of the IC's on the PICkit board is bad. I wouldn't expect, although I don't know for sure, the MOSI and MISO pins to both go high or low at the same time if you only have power on one of those pins.Code:MCP_WRITE: low CS SSPBUF=64 GOSUB CLOCK_BIT SSPBUF=MCP_ADDRESS GOSUB CLOCK_BIT SSPBUF = MCP_DATA GOSUB CLOCK_BIT high CS return
Hi Christopher;
Check this wiki article. It shows how to handle the MCP23S17. Maybe can help you if you adapt to your ic.
http://www.picbasic.co.uk/forum/cont...P-PBP-MSSP-ASM
Thanks and Regards;
Gadelhas
