Only one thread on the 23S08. Well, maybe someone can help.
I believe my problem is in the hardware but if someone can check the command below, that would be great. I took the attached file in the first thread and believe only the write command needed to be changed. I modified it to this but I still get nothing out of the 23S08. I'm using the PICkit serial SPI board.
MCP_WRITE:
low CS
SSPBUF=0
GOSUB CLOCK_BIT
SSPBUF = spout
high CS
I feel like something is missing in there. Also, to rule out the board, I was toggling one pin at a time. When I toggle the MOSI or MISO pins, the both appear to be connected because both pins go high and low at the same time. In other words, I pulse the MOSI with a 2 Hz signal and the MISO pin appears to be in parallel.
Confused....
