Nope, you're 100% right...for most (like 99.9%) cases.
If you've got any assembly going on, for instance DT's Instant Interrupt's, they might get a chance to execute in the middle of most PBP commands, but otherwise, one statement at a time.
SERIN hardly needs any time to decode anything, maybe if you're using some of the SERIN/SERIN2 modifiers, those might need a few instruction cycles to execute.Maybe I should reiterate what I asked:
I have learned recently that "Serin" does not have a buffer therefore it needs some time to decode the data it receives. If I have multiple serin sequences one after the other, how long do I need to wait in order for the code to be received correctly. Below is an example of what I am asking:
SerIn porta.0, T2400, Data1
pause ???
SerIn porta.1, T2400, Data2
pause ???
SerIn porta.2, T2400, Data3
pause ???
Continue with code*********
But any 'decoding' that needs to be done needs to be done by the person behind the keyboard.
SERIN doesn't know A from B, doesn't know that it needs to jump to here if it gets an A, or set this to that if it receives a B. That's all you. It's up to you to figure out how to receive data continuously and how to process it without missing any data coming in.
