GPS Tracker Project ( GPS Module + JP Module + LCD Dispaly )
Results 1 to 2 of 2
    Jul 2008
    Default GPS Tracker Project ( GPS Module + JP Module + LCD Dispaly )
    Hello all,
    I just finished a summer project which is a GPS tracker demonstration program with data logging capacity. It uses BasicStamp 2P (also you can use PIC chip) to interface with a GPS Module, JP Module and 16x2 LCD display. Sample code used is standard PBasic 2.5 ( It can be changed to PicBasic or PicBasic Pro very easy).
    It can record GPS data to a MMC/SD card with latitude and longitude information. The data can be processed from Google Map at the website: http://www.gpsvisualizer.com. If you have Google Earth installed, the data also can be processed into a KML file (Google earth data file format) at the website: http://www.gpsvisualizer.com/map?form=googleearth
    Main components:
    (1) Basic Stamp 2P
    Manufacturer: www.parallax.com
    Datasheet: http://www.parallax.com/tabid/440/Default.aspx
    (2) GPS Module 40EBLS
    Manufacturer: www.mightygps.com
    Datasheet: http://www.mightygps.com/oem/MightyGPS40EBLS.pdf
    (3) JP Module
    Manufacturer: www.jianpingusa.com
    Datasheet: http://www.jianpingusa.com/datasheet...nstruction.pdf
    (4) 16x2 LCD Display
    Manufacturer: http://www.femacorp.com/
    Datasheet: http://www.femacorp.com/Products/LCD...es%20Index.htm
    (1) Schematic
    (2) Code (File attached)
    (3) Project photo
    (4) Google Map
    (5) Google earth map (Map pictures attached)
    OldSpring (Author of the project)
    Default Great Project - thanks for the MMC tip
    I had been looking for a 'potted' solution for MMC to use a s a large but slow store for data logging. I tried the chipset from Compusys (Ron Diol) and it works but this looks like a cleaner implementation. I have ordered two JP modules and will let the forum know how thye work.
    Cheers
    BrianT
  1. first project, and yes, doesn`t work
    By bogdan in forum mel PIC BASIC Pro
    Last Post: - 28th April 2009, 06:13
  2. PIC16F684 + 8*2 LCD module
    Last Post: - 5th March 2008, 23:38
  3. Need help with LCD number display.
  4. LCD will not start
  5. Gps with 16f628
    By dragons_fire in forum mel PIC BASIC Pro
    Last Post: - 8th June 2006, 03:38
