hpwm error
Results 1 to 10 of 10
Thread: hpwm error
    Quote Originally Posted by manwolf View Post
    If you have the datasheet did you notice the note?
    Note 1: The CCP1 pin is determined by CCPMX in
    Configuration Word 1 register. You have a choice of 1 of 2 pins.
    Note: The TRISB bit (0 or 3) is dependant upon
    the setting of configuration bit 12 (CCPMX).
    And looking further in the datasheet, the default values of CONFIG1 are all 1's, which for the CCPMX bit means CCP1 is on PORTB.0.
    I'd bet a LARGE sum of money that it's the equal sign.
    May 2008
    Florida
    Darrel
    I was not trying to override your suggestion, just asking cpillips82 if he noticed the note. It caught me by surprise is all.
    I always bow to your experience. I am lucky if I don't get smoke when I plug something in.
    I read every post and see if I can follow through on everything. Turns out I searched the datasheet for the wrong thing. Looked for CCPMX not CONFIG1.
    PS NO BET, I be flat broke I play with PICs because they be cheaper than cars!
    But if you every get down my way I'm always good for at least one beer.
    Sorry to butt in cphillips82, I will crawl back into my hole now.
    Darrel
    Exactly what you should do. On both accounts.
    Beat me up, prove me wrong, show a better way.
    And so will I, in reverse.
    Don't even.
    Apr 2008
    it was the = sign, thankyou very much.
  1. Loop with two motor and 2 sensors
  2. Optimizing DIV
    Last Post: - 22nd September 2008, 04:58
  3. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 14:14
  4. 3 HPWM channels
    Last Post: - 4th April 2006, 02:43
  5. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 00:22
