port config.
Results 1 to 4 of 4
Thread: port config.
    May 2008
    Default port config.
    I wanna use port a (analog input) for analog digital coversation
    other port as digital
    port b for lcd output
    input port c 2 for frequency measurement
    port c 3 scl
    port c 4 sda
    port c 6
    port c 7
    for rs 232 comminication with max 232
    and port d all digital output
    how can I config ports
    please help ....
    Assuming you're using PicBasicPro (like the title of this section of the forum says), I assume you are using MeLabs PicBasicPro, and therefore, I can infer that you have or have access to the PicBasicPro manual, which contains instruction on how to configure an ADC port, how to set ports for input and/or output, how to set up a serial port (baud rates, pin configuration, etc) and how to set up the I2C module and pins.
    So what exactly is the problem then?
    May 2008
    Florida
    Lightbulb
    I find the Help button in PBP is very useful also. Try ADCIN, code you can cut and paste...
    Quote Originally Posted by manwolf View Post
    I think the HELP button you may be referring to is actually in Microcode Studio...
    But yes, it is VERY helpful...
  1. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 23:51
  2. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 17:20
  3. Microcontroller with 2 way paging application problem
  4. PortE problems (PIC18F4455)
    By RubenR in forum mel PIC BASIC Pro
    Last Post: - 12th July 2006, 15:26
  5. Installation sequence
    By Demon in forum General
    Last Post: - 11th July 2006, 03:56
