12F683 internal pull up
Results 1 to 8 of 8
    Sep 2007
    Default 12F683 internal pull up
    Seems that internal pull up resistors not working?
    Simple code to work with. I am using GPIO.5 as input as digital. The LED still blinks from GPIO.2. The internal pull up dont work as expected to keep input low. Am I missing something?
    CODE:
    Include "bs2defs.bas"
    @ DEVICE PIC12F683,MCLR_OFF,INTRC_OSC_NOCLKOUT,WDT_OFF,BOD_ ON, PWRT_ON
    A var word
    OSCCON = %01100000 ' Internal 4MHz osc
    ADCON0 = 0 ' A/D off
    CMCON0 = 7 ' Comparators off
    ANSEL = 0 ' Set all digital
    WPU = %00110111 '0 ' Internal pull-ups = off ISSUE?????? Register 4.3
    OPTION_REG.7=0 'Enable internal pull-ups
    TRISIO = %100000 'set GPIO.5 as input, rest output
    test var GPIO.5 'Input
    START:
    LOW 2
    PAUSE 100
    if test = 1 then high 2:PAUSE 1000
    goto START
    The LED still flashes. it should not be flashing unless input is triggered from +5 volt.
    The internal pull up is a weak internal pull up, easy to over ride it with almost any external drive (parameter D070 in the datasheet), only about 250uA of current for pullup.
    If you have internal pull-ups ON, and you're testing the input pin for logic 1, the only
    way your LED shoud NOT blink would be when GPIO.5 is pulled to ground.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2007
    Thumbs up Works
    Got it working, added INTCON=7. changed input to PULSIN. Everyting is working well.
    OOPS should be INTCON=0 not INTCON=7.
    Quote Originally Posted by hvacrtech View Post
    I'm not seeing where the INTCON or the PULSIN statements should make a difference...
    And if you look back at your first post:
    Why would the internal pull UP work as expected to keep the input LOW?
    Err, OK, but INTCON is already zero, by default, at power-up. Not sure where PULSIN fits into the grand scheme, but at least you got it working...;o}
    -Bruce
    tech at rentron.com
    Sep 2007
    That way it been erratic behavior and You are right about that the led should not blink when GPIO.5 is opened. that way when I opened the path from ground, the led still blinks. After I added INTCON=0 to it, it behaves much better and dont blink when opened. When I closed the GPIO.5 to ground, the led did blink.
    I dont know why but added INTCON=0, system stablizes. Like other PIC I know dont have issues with out this configuration. Maybe it a requirement?
    Clearing INTCON should not be necessary unless you had previously placed some value
    in it you need to clear. At power on INTCON by default is already clear.
    If it wasn't you could really have some odd behaviour with unexpected interrupts firing.
    -Bruce
    tech at rentron.com
  1. Internal vs. external osc for comms
    By mtripoli in forum mel PIC BASIC Pro
    Last Post: - 29th January 2010, 15:58
  2. 16F688 Internal clock and MCLR
    By manxman in forum mel PIC BASIC Pro
    Last Post: - 18th August 2007, 19:38
  3. 16f677a to 12f683
    Last Post: - 25th July 2007, 07:16
  4. Use internal program memory like DATA memory
    Last Post: - 30th December 2006, 19:38
  5. PIC12F675, accuracy of baud rate with Internal Oscillator
    By Chris Mayhew in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 23:41
