better way
Results 1 to 7 of 7
Thread: better way
    Aug 2005
    down south
    Default better way
    As always I looking for a better way, I know this is NOT the way a real programmer would do it
    thanks
    PBP 16F676 TO 16F676 TO LCD
    THE MANUAL SAYS
    ‘ Wait until the character “A” is received
    serially on Pin1 and put next character into B0"
    WHATS THE BEST WAY TO SEND "GROUNDED" FROM ONE PIC TO PIC TO LCD
    THIS WORKS BUT THINKING THERE MITE BE A BETTER WAY
    TX
    SEROUT PORTA.0,N2400, ["GR"]
    RX
    SERIN PORTA.0,N2400,["G"],B0
    IF B0="R" THEN LCDOUT $FE,1,"GROUNDED"
    " be nice it's people like me that make people like you look smart"
    yes I read the datasheet, of the 300 pages I understood 10
    That looks about right.
    You do realize that you are not sending "GROUNDED" but just sending "GR"
    The other ways of using hardware serial or maybe the SERIN2 command or DEBUG may or may not be a "better way", depends on what you are doing. SERIN/SEROUT is fine for basic stuff , SERIN2 gives more options....
    Are you looking to make an LCD serial backpack?
    If so, there are a few decent examples of that here on the forums.
    Just do a search...it's out there...
    Aug 2005
    down south
    Smile
    yep mackrackit just "GR"
    skimask if backpack is what it is called when you turn a $9.00 LCD into a $35.00 LCD
    thats what I'm trying to do. Now I Know what to search for
    thanks to the both of you
    Aug 2005
    down south
    I just "print PDF" that one along with some more to study up on.
    make it easier when you at least know what to search for LOL
    thanks
    Quote Originally Posted by grounded View Post
    skimask if backpack is what it is called when you turn a $9.00 LCD into a $35.00 LCD thats what I'm trying to do. Now I Know what to search for
    Yep, basically, you take one PIC, write the code, replace LCDOUT with SEROUT, take another PIC and use SERIN to get the LCDOUT.
    Make any sense? It will after you muddle thru that link above...
