Problem using Else
Results 1 to 40 of 47
    ok, on the transmitting side after stripping everything down I am sending the data for the button that is pressed and when I release each button I send the data again and it clears that particular output on the receiver. Seems to work ok. Thanks for everyones help and I read something here on the forum about closing the post when finished so,... if so how do I do that?
    Quote Originally Posted by tazntex View Post
    Well, what I'm trying to do is show you a much better way of doing things, one that's much much easier to read thru and takes up a lot less code space, by breaking it down, and building it back up again.
    Closing - I wouldn't worry about it. I think I've only ever seen a handful of threads that are closed here.
    Thanks Skimask and everyone else who has helped me. I appreciate you trying to teach me by giving pointers, but this has been a rough one I am by no means a quitter, thought about it though, especially through the last couple of post. I am laughing now. Everything seems fine. I can pressed the button now portb 1-4 are momentary and stay on as long as I am pressing then go off when I release them. Every once in awhile one will stay on and I'll press the button and release it and that output will clear. Thanks again to all
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 19:52
  2. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  3. Microcode Studio 18f2455 problem?????
    By volkan in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 21:04
  4. Hardware problem or what ?
    By Steve S. in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 21:39
  5. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 22:59
